7520 w/dead fuel gauge
Jeff Leavitt
10-08-2004 20:53:38
I have 7520 with a dead fuel gauge or sending unit. How do I tell what is the problem. I dddo have battery voltage at the stud on the sending unit.
Thanks in advance.
Jeff
JD Jerry
10-09-2004 04:41:11
 Re: 7520 w/dead fuel gauge in reply to Jeff Leavitt, 10-08-2004 20:53:38
My 7520 read empty. I unhooked the sender and grounded it out and it would read full. The float was full of fuel. Deere no longer sells the floats but you can pick up one from ford that is identical.
Bob
10-08-2004 20:57:52
With the key switch "on", and the wire unhooked at the sender the guage should read either full or empty. (Deere used two different systems, and I'm not sure which was used on the 7520.) When you touch the sender lead to chassis ground, the gauge should move to the opposite end of the scale, and then when you remove the lead from chassis ground, the gauge should go back to where it was in the first place.
If the gauge works in this manner, you likely have a bad sender.
