4320 vs 1256
fredy
10-08-2004 07:42:39
Are the two tractor pretty comparable in power
and pulling ability? Also question below for ya.
2cylfarmer
10-09-2004 19:26:59
 Re: 4320 vs 1256 in reply to fredy, 10-08-2004 07:42:39
Our 4320 is a good puller, but likes to visit the fuel barrel.
buickanddeere
10-09-2004 15:12:14
If you are a Deere fan the 4320 is supperior. If a IH fan the Binder is the better tractor. What was the 1256 rated at anyways?
lynn
10-10-2004 07:29:06
 Re: 4320 vs 1256 in reply to buickanddeere, 10-09-2004 15:12:14
buickanddeere..Nebraska test 971 put the 1256 at 105.82 dbr. and 116.12 pto.. the 4320 is rated at 104.49 dbr. and 116.55 pto test 1050..lynn
lynn
10-09-2004 04:25:21
fredy..the 1256 as stated below will outpull the 4320..they both have the same size motor but the 1256 is rated at 2400 rpm while the 4320 is 2200 rpm..ta on the 1256 gives extra gearing over the 4320..hydraulics comfort brakes handling go to the JD..lynn
fixerupper
10-08-2004 20:39:08
Back in the early 70's I ran both a 4320 and a 1256, and if I remember right the 1256 could out pull the 4320. The 1256 was pulling a 6-16's plow and the 4320 was pulling a 5-16's. The 4320 was easier to shift and the hydraulics were far superior over the 1256's, but the 4320 was VERY gutless at low R.P.M.'s, meaning it had to have pretty good engine speed when turning on the ends of the field or it would give up and die. I don't remember what the fuel economy difference was.
Stuart
10-08-2004 10:39:51
A 1256 was basically a turbocharged 856 with a 407 ci motor. Its a toss up
960
10-08-2004 09:42:15
I am green, green, green and farm with such. I have helped neighbors with 56 IH's. A 4320 is a great tractor but stock engine on each a 1256 will eat a 4320. Now for ease of operation and spending a full day on one the 4320 is ahead.
lopper
10-08-2004 08:01:25
I dont know about 4320's but 1256's were a hard pullin' SOB.
