45-4620
fredy
10-07-2004 19:26:03
There is a 69' 4520 selling locally for 10,500.
The tractor looks tight and clean but i was wondering if there is anything that can be done
with the 1000 rpm pto shaft for 540 light operation? Also the engine is not intercooled
but in my i&t manual it say later ones are.Is there a way to put one on easily? Anything else
to look out for?thanks alot
CMB
10-08-2004 08:47:39
 Re: 45-4620 in reply to fredy, 10-07-2004 19:26:03
I've had a 4620 since about 1980. It's basically a bulletproof tractor, even considering the fuel delivery has been set to produce almost 170hp as long as I've had it. I've heard that the early 4520's had some engine problems, just what, I don't know, but supposedly John Deere would fix your 4520 engine once under warranty, or trade for a 4620 engine for $8oo. I've been told that most owners who had trouble chose to update to the 4620 engine.
billyiron
10-08-2004 07:22:40
the 4520 was an old war horse pretty much bullet proof, I dont think the after cooler is needed but you can bolt a after cooler on with no problem, you could put a 540 adapter on the pto and run the engine slow but its like a bandaid for a broken neck,,I know no real solutions to run rated power for 540 equipment, maybe a gear box of some sort
fredy
10-08-2004 07:36:37
 Re: 45-4620 in reply to billyiron, 10-08-2004 07:22:40
Thanks billyiron.So in other words get a 4320.
How durable were those tractors.intercoolerable?
THANKS
