730 Rockshaft Seal???
BobK
10-07-2004 18:42:54
I have a 730 Diesel that is pouring fluid out around the rockshaft, right behind the arms. Talked to my dealer today and he can get the seals, and what looks like bushings. My question is this, can you just take the arms off and pop the seals out and install them from outside, or is this a major job, like taking the seat off and the top of the rockshaft housing? Any ideas?? Thanks
Bob
F-I-T
10-08-2004 19:18:15
 Re: 730 Rockshaft Seal??? in reply to BobK, 10-07-2004 18:42:54
Bob:
I haven't had one apart in years, but oer the parts book, it does look like you could install the seals only from the outside. Now, if the bushings were severely worn, so that they would tend to wear out new seals early, and would need to be replaced, you would likely have to go in through the top so that you remove the rockshaft and drive the bushings out and the replacements back in. Even with removing the seat et al, it shouldn't be too tough a job for the benefits yoou'll likely receive.
Frank
