4020 VS. 4010
mlshvb
10-07-2004 15:35:26
Hey guys, got a question. What were the major differences between the two tractors,and what were the problems? I was always told to stay away from the 4010's, but nobody really explained. Do they both have the same diesel engines? There is a 4010 on a sale on Saturday, and it looks pretty sharp. Just wondering what I should look for.
Thanks in advance
JD Jerry
10-08-2004 06:57:27
 Re: 4020 VS. 4010 in reply to mlshvb, 10-07-2004 15:35:26
I have a 4010 and a 4020. The 4010 has 2 less bolts in the side rails that would make it weaker for a loader,and you can"t lock the brakes together. The 4020 has a powershift and It is on a loader. I have never used it to pull a load but my son pulled a 21"6" disc with it one day and said it handled it well. The 4010 has pulled the disc, a 21" vibra-shank and a 21" disc drill. It handles them well. The 4010 dynos at 105 hp, has 15,000 hours but is mainly used for haying now. The 4020 has 8,500 hours ( have never had it on a dyno and is used for the loader. Both tractors have gave excelent service.
Rodney A. Johnson
10-08-2004 06:28:07
This has been discussed many times before in this forum. May be worth searching (using your title) and perhaps you will find some helpful information.
I've seen many 4010s go for less than 4020s, but have also seen some 4010s gor for the same or more than some 4020s...depends upon whose bidding...
If you are going to put a loader on, the 4020 should be better due to bigger hydraulic lines (1/2" vs. 3/8") and a higher pressure pump (course you can turn up the pump on the 4010).
Another weakness (if you want to call it that) was the light weight of the 4010. 4010 row crop is a little over 6000#s. Where as 4020s are between 8000 and 9000#s. So, it will take more weights and fluid to get the tractor ballasted for any hard pulling (doesn't do much good to have 100+ hp and not have the traction to pull...unless it is only needed for PTO work).
CMB
10-07-2004 17:32:19
4010's were (and are) great tractors. They are about 95% of a 4020 at about 1/2 the price! I've owned a 4010 since 1967 & wouldn't pay any difference to get a 4020. Mine has M&W pistons, A turbocharger, plus the seven bladed fan & the big oil pan----- ---- will turn 110hp all day long & stay cool, it's been this way for over 4000hrs. All in all simply a tractor that I will NEVER get rid of!!!!! !!!!! The" biggest little tractor"that was ever built!!!!! !
mlshvb
10-07-2004 21:36:20
 Re: 4020 VS. 4010 in reply to CMB, 10-07-2004 17:32:19
Is there any physical things I could look for to see if the 4020 engine updates were done to the 4010? Also, what would I be most worried about the 4010?
Thanks
KIP
10-07-2004 16:19:10
We never had any problems with our 4010D from the time we bought new in 1963 until we sold it with the farm in 1981. Great machine!
mlshvb
10-07-2004 16:22:14
 Re: 4020 VS. 4010 in reply to KIP, 10-07-2004 16:19:10
Thanks,
Do you know it the syncro trans and rear end were the same in the two tractors.
2cylfarmer
10-09-2004 19:17:37
 Re: 4020 VS. 4010 in reply to mlshvb, 10-07-2004 16:22:14
I have a 4010 with a 4020 engine kit and really like the tractor. But most of the 10 series tractors that I have had, have made a howling sound from the rear end in 8th gear at higher engine speeds. Deere mechanics tell me that this is normal for 10 series because of the machining of the ring gear & pinion. I pulled the rockshaft housing on this tractor, inspected the gears and checked the backlash on the ring gear. Everything looks good, but it still howles on the road. 4020 tractors do not do this.
If you ever want to change PTO speeds between 540 & 1000, you will appreciate the 4020 system.
Heat Houser
10-07-2004 20:15:38
The rear ends are not the same. The major difference is the PTO shaft with it"s shifting mechanism on the 4010. Another difference was rear axle size. The 4010 axle is the same OD as the 70,720,730 two cylinders.
The 4010 used cast iron in many places while the 4020 used nodular iron due to the higher loads.
