JD 40 Blow By Follow-Up
Cal B
10-07-2004 13:52:41
I am attempting to run my Model 40 long enough to see if the blow by will clear up before I tear into the engine. I poured some Marvel Mystery oil in each cylinder for a couple of weeks, then blew it out and installed new plugs. Cranked her up and she ran for a while. As she heated up, I began to notice the black froplets that indicate blow by. I cranked her full open and she ran on up. I watched oil pressure and temp closely. After a few minutes, maybe 10 to 15 she quit jst like the fire had been cut off. I pulled the plugs and put new ones in again, but she still won"t fire. Good sparks from the wires so spark should not be the problem.
What am I likely looking at, clogged carb jets? BTW I rebuilt the carb before all this took place.
Thanks again for advice. I am learning a lot about this beautiful old machine.
CPeter
10-07-2004 19:31:50
 Re: JD 40 Blow By Follow-Up in reply to Cal B, 10-07-2004 13:52:41
Maybe you want to pull the valve cover and see if you have a loose rocker arm or two. That would indicate a valve stuck part way open. When you choke it does gas run out the carb?
CPeter
CPeter
10-07-2004 15:54:44
How is the compression? Did you loosen up some carbon that is holding a valve or valves open? Why do you suspect the carb?
CPeter
Cal B
10-07-2004 17:36:18
 Re: JD 40 Blow By Follow-Up in reply to CPeter, 10-07-2004 15:54:44
Compression on one cylinder is good, on the other it is way down. I suspected the carb because of the way the tractor stopped. It was just like the gas was cut off.
