12 volt positive ground question
Mike in tn
10-07-2004 07:19:11
What is the correct way to hook up jumper cables to a 12 volt positive ground system.
Thanks,
Mike
WTW
10-07-2004 07:56:03
 Re: 12 volt positive ground question in reply to Mike in tn, 10-07-2004 07:19:11
Mike, It doesn't matter if one or both vehicles are positive or negative ground when jumping from one to the other, just pay attention to the battery post markings and hook jumpers pos. to pos. and neg. to neg. the important thing (not to do) is if the two vehicles are opposite polarity is not have the bumpers or frames of each vehicle touching each other when jumping a battery as this will short circuit the different polarities. Just go by the markings on the battery and not what the cables are hooked to.
Bob
10-07-2004 07:53:31
Simply match the cable polarity to the identifying marks on the battery...
Red (+) cable to (+) post on battery.
Black (-) cable to (-) post on battery.
(At both ends of the jumper cables. Be sure metal chassis parts of the (+) ground vehicle and the (-) ground vehicle do not touch.)
CLW
10-07-2004 07:38:09
The pos. lead of the charger to ground cable of batt.. Neg. lead of charger to neg. post that goes to starter. Just backwards of how you charge a car batt.
CLW
