Carb paint
Rod
02-06-2004 07:25:54
I bead blasted my carb and now would like to coat it with something to stop the rust. Is there a good paint or clear coat that is gas resistent or any other ideas? Thanks
Chris
02-07-2004 08:04:26
 Re: Carb paint in reply to Rod, 02-06-2004 07:25:54
I haven't found a paint yet that won't run off a leaking carb. If your carb has been rebuilt and doesn't leak I would get some good ol' John Deere Blitz black and paint it up. I have found that if you use a satin or flat finish on them the paint won't fade if you do get gas on it. I usually have to repaint mine about once a year or so. Usually have to touch up before shows. They usually don't leak but on occasion they have a problem. Make sure your carb is very clean and dry and don't put on a really heavy coat. Then again, you never know they might make a paint designed for that but I haven't found it. Hope I helped a little.
