Is PB Blaster useful on seized engine?
Lance
10-23-2003 09:51:55
Just wondering. Lance
dave s
10-23-2003 23:22:58
 Re: Is PB Blaster useful on seized engine? in reply to Lance, 10-23-2003 09:51:55
I had excellent luck using it on my uncle's siezed wd allis. That motor was stuck for at least 10 years . I sprayed 2 cans in it and pulled the oil plug , in about 20 minutes the stuff came running out so I grabbed the crank and the motor was free. I was pretty amazed!
Paul from MI
10-23-2003 18:25:11
Be really careful unsticking an engine. Time is your friend. Lots of times the valves are stuck worse than the pistons, and you can do some serious damage if you don't take it apart piece by piece until you are sure you won't damage anything. PB Blaster is my favorite penetrant, but I still would pull the head and take anything else off that could be stuck before using any significant force. When I unstuck my D I removed the cylinder with pistons & rods intact, then pressed the pistons out. It took 8-1/2 tons to move them, but nothing was damaged. Go easy on it.
Paul
Robert in W. Mi
10-23-2003 16:42:52
Blaster works a LOT better than WD40! It's one of the best penentrates made today. I like liquid wrench too. Robert
Rob
10-23-2003 13:29:37
Never used it but it should work. I unstuck the engine on my neighbor's Allis Chalmers WD 45 using WD 40. Took all the plugs out poured about a cupfull of WD 40 in each cylinder and Hung 2 John deere suitcase weights on the hand crank and left it. Came back the next day and she had broken loose.
