JD 401C Tachometer Drive
JPease
10-06-2004 14:45:16
I am looking for info on what drives the tach on the 401C. I see the tach cable going into the clutch housing cover on the right-hand side, but can"t determing what"s inside. I looked in the service manual and at the on-line parts catalog and can"t find any detail on the drive. The tach doesn"t work and I would like to repair it. Any info appreciated.
david val
10-08-2004 04:48:11
 Re: JD 401C Tachometer Drive in reply to JPease, 10-06-2004 14:45:16
inside the cable you see runs a flexible shaft (which is a special steel cable also) that transfers camshaft rotation to tach.
the tach cable comes as a complete unit (internal and external). if you remove the cable from the tach and with the engine running the inner cable doesn't rotate, the cable is bad.
david
