3 pt plow or trailer plow - which is better for 72
Markus
10-06-2004 09:06:25
Looking to buy a 3 bottom plow...cant decide wheter I should get a 3 pt unit or a trailer pluu plow...I have a 3 point hitch and like the smaller 3 point unit, but a trailer plow could be used on my other tractors that lack a 3 point...is there a price difference and what handles/plows differnet?
Loren-MN
10-07-2004 20:26:33
 Re: 3 pt plow or trailer plow - which is better fo in reply to Markus, 10-06-2004 09:06:25
I hate to change colors here boys. I'm green just like the rest of you. The best combination I ever used was an International Model 70 3-16 plow behind the 730. Better clearance the the JD plows. Hardly ever plugged, even when we got in a hurry and didn't always chop the corn shalks. Loren-MN
Loren-MN
10-07-2004 20:33:25
 Re: 3 pt plow or trailer plow - which is better fo in reply to Loren-MN, 10-07-2004 20:26:33
I should add. I am semi-retired. Don't farm full time, but do work for several friends or neighbors in the area. Plowed for a guy last fall with a Ford/New Holland/Versatile (yes all 3 names are on the tractor someplace) with a John Deere 8 bottom variable width plow. Great plow, but might be just a bit much for your 720.
Loren-MN
johndeeregene
10-06-2004 21:01:23
here is the one thing no one has mentioned yet. you go to the plowing matchs or plow days an if there is any trash in the field or stnding cornstocks the fully mounted plows do not have the cleareance you need an will plug up alot more. they all have there place but for everyday plow an haveing fun unless unpluggin the plow is fun i would go with a trailer plow. around here most pull a 3 16 with there 720 730. yes it is a little small but they go a gear higher an do much better job of plowing. some do use a 4 14 but the 14 inch is not as good in trash as the 16 inch is. i plow with a 3 16 with my 70 diesel. last weekend we had a plow day an i didnt plug up one time in standing cornstocks. the fully mounted did an so did the 14 bottoms. have you thought about a semi mount. like a F145 plow. you might get away with a 4 16 but more then likely a 4 14 they were a pretty good plow. if you decide on a trailer plow i would look for a 666 or a 777 they both were very good plows an full roller bearing. this is just what i have noticed an what i have learned. johndeeregene
Leroy
10-06-2004 17:43:46
On tough going a trailer type will hold in place better, small areas mounted easier to handle, semi mount has some of qualities of each, each has it's place
Indydirtfarmer
10-06-2004 09:57:19
All depends... Are you using it for farming lots of ground, or is it for plow day? Will you be plowing a garden, or a 40 acre field?
Here's my take on the issue; I like mounted plows, up to 4 bottom. Beyond that, semi-mounted. Drawn plows are slower to turn, and provide no increase in traction, as will a mounted plow.
If you're strictly in it for "old time sake", drawn plows are OK. If time is an issue, mounted is the only way to go.
All I can add is that when mounted plows came on the scene, drawn plows all but disappeared from dealers inventories. The American farmer cast his vote..... ...John
Markus
10-06-2004 09:07:24
Forgot to mention, this is for a 720 Diesel with 3 point.
RalphinWI
10-06-2004 11:36:04
 Re: 3 pt plow or trailer plow - which is better fo in reply to Markus, 10-06-2004 09:07:24
I very much much prefer a drawn plow, unless you are going to plow a small garden, then use a fully mounted which leaves a sawtooth pattern at the end of the field (back bottom is first out of the ground). Brother has a 4 x 18 semi-mounted on a 4240. It the ideal machine for the hired help to use to make a mess out of the field. Controlling the 3-point, the landing lever and the tailwheel depth simultaneously is beyond most. Also if you don't insist that they get the plow out of the ground before they start a turn they shear bolts from the hitch or worse. My favorites are late models with a castering tail wheel. An 820 JD with 4x16, no fluid, 3 sets of weights runs out of power before it runs out of traction. There is weight transfer from the plow, but major transfer is from the front to the back wheels of the tractor.
mike brown
10-30-2004 14:26:06
 Re: 3 pt plow or trailer plow - which is better fo in reply to RalphinWI, 10-06-2004 11:36:04
I too have an old IH 70 4-16 that does a smoother job of plowing than just about anything out there. I used to plow for guy that planted rye for cover crop in the fall. By mid may the rye was as tall as the tractor wheels but that plow with trash covers turned it under so you couln't see a spear of rye. I made a buster bar for it and made a sliding drawbar where it attaches to the plow and mounted a small hyd. cylinder so I could adjust the cut for side hill work. I now pull it with a 4230 so no power or traction issues.
