JD 214 - Breakers? (SILENT AUCTION WOES!)
Swing Kitten
10-06-2004 08:37:37
I bought a John Deere 214 at a silent auction and was excited to get it home and all tuned up. (Apparently, the previous owner had taken good care of it until he was no longer able to do yard work - apparently it sat in the garage a few years before he, unfortunately, passed away.) I went online to bid on an owner's manual and bought all the necessary oil, gas, grease, spark plugs, etc.
HOWEVER, a somewhat "in-the-know" acquaintance said the tractor had major issues. We paid to have it assessed by a tractor repair/maintenance vendor and were told:
It would cost $700-750 to fix.
The battery was almost dead, but they got it to turn over.
All belts needed to be replaced.
No ignition and no compression � some valves stuck open.
Probably needs a new set of breakers.
MY QUESTIONS:
What the heck are breakers?
Is it useless that the valves are stuck open?
Should I give up on it and try to sell it off at a loss?
I do not know anything about tractors/mowers, but I love to learn new things and like to get my hands dirty (I do all the handy work in our house). I just need to know if these issues are beyond my potential ability.
Can anyone give me some advice? Thanks!
CPeter
10-07-2004 06:26:50
 Re: JD 214 - Breakers? (SILENT AUCTION WOES!) in reply to Swing Kitten, 10-06-2004 08:37:37
I hope that your "somewhat "in-the-know" acquaintance" isn't going to help you out by taking that piece of "junk" off you hands. I have seen this happen before. From what you say, there isn't much that can't be fixed and in fact most of what you describe is in the area of routine maintenance. Those old JD garden tractors are in high demand and are made of tough stuff. This will outlast two of the new ones, so fix it up and you will be happy with it. Any used equipment needs a good going over to find and fix the minor things before the become major problems.
CPeter
Donny-B
10-06-2004 17:22:50
Swing Kitten, The 214 is a heavy duty machine that will last for many years if maintained. Belts, points, & tune-up stuff can be purchased from aftermarket suppliers like "Stens" for less then half what dealers want. A battery at your local tractor supply will run $25. As far as the compression, Mark is correct about the ACR (automatic compression release) The Kohler singles have a weighted unit on the cam that holds the exhaust valve partially open until the engine starts. This aids the starter in cranking. If you are planning on keeping the tractor for a work unit I would purchase an owners, parts, & service manual and go over the tractor. It makes for a good winter project! Good Luck.
Mark57_420
10-06-2004 10:21:06
Belts and stuff can add up in hurry, but you"ve definitely got one of the best mowers ever made (in my humble opinion). I am in the process of rebuilding my late father"s 214. He purchased it new in 1976 and it saw HEAVY use (and abuse) on the farm for many years, mowing 3+ acres of lawn weekly, pulling empty wagons, pulling augers, etc. He even ran it into the pond and it went completely under while running. No engine damage, but it did need everything drained and cleaned. I think I can expect another 10 or 20 years out of this mower when I"m finished.
Be careful checking the compression on this engine. It has a compression-release for easier starting. The starter will not spin the engine fast enough to disable the compression-release, so you have to rig up a rope starter to check the compression.
F-I-T
10-06-2004 09:46:08
Swing:
Bob's points are right on. I restored a basket case 214 with electric lift nearly 20 years ago and it is still being used today. Armed with a book and some very simple tools, you should be able to install the needed belts, install the breaker points, and probably get the valves to unstick. Actually, turning the engine over to top dead center and pouring some diesel fuel in through the plug hole will go a long way towards having them unstick themselves.
Get your books (the service book is particularly thorough) and post back here when you have questions.
Frank
Bob
10-06-2004 09:06:47
The engine is a Kohler K-321. You can download a service manual in .pdf format for free at :
www.kohlerengines.com
The sticky valves are no big deal. There you can loosen them in place with penetrating oil, or remove them for a thorough cleaning, following the service manual.
"Breaker" could mean breaker points on the engine ($8 - $12), electrical circuit breaker, located in the lower dashboard-to-under the battery area, ($5 - $8), or, if the machine has electric lift, there would be more electrical circuit breakers there.
If you are going to fix it up properly, and keep it around, owner's, service, and parts manuals are almost a MUST. Often, they come up on ebay, or the can be bought direct from Deere Service Publications at 1-800-522-7448. The genuine manuals are pricey, but very complete and thorough.
Most parts are still available from Deere, MOST at competitive prices.
Have you checked out:
www.weekendfreedommachines.org
