John Deere 4000
Big Yarber
10-05-2004 07:44:27
At home we have a kind of rare tractor a JD 4000. if anyone know anything about it could you tell me. i have been trying to research it but have had little luck finding anythin about it. it is a narrow front with rollomatic i believe. single hydrolic, 3-point, no cab/ROPS and pto. i would appreciate any info.
Garland
10-05-2004 17:25:30
 Re: John Deere 4000 in reply to Big Yarber, 10-05-2004 07:44:27
Yarber Your 4000 how is equiped,Gas,Diesel,synchro range, or power shift.John Deere only made nine gas power shift 4000's. If you could get hold of a issue of Green Magazine Aug.1996 if will have all the uinfo in it. Thank Gman
Big Yarber
10-06-2004 11:29:59
 Re: John Deere 4000 in reply to Garland, 10-05-2004 17:25:30
Its a Diesel Syncro Range. thanks for all the info
WTW
10-05-2004 11:35:51
The 4000 model John Deere tractor is basically a stripped down version of the late model 4020. The final drive gears and all transmission parts with the exception of the lack of reverse synchronizer, are the same as the late model 4020. The 4000 did not have a synchronizer on reverse shift where the 4020 did. The axle shafts from the final drive planetary out is stepped down to the same (diameter) as the 3020 / 4010 axle shaft size (3.125 verses 3.375). The axle shaft and final drive housing (part) was unique to the 4000. They used lighter cast wheel centers on this axle. The 4000 did not have the sheet metal covers on the rockshaft nor did it have enclosed battery boxes. A lot of people believed that the 4000 tractors had a lighter rear end in them (3020) that was not true. A parts book will show that the engine, clutch, transmission and parts, final drive gears and hydraulic system are all the same as the late 4020. To confirm what is and is not the same parts as a 4020 refer to a parts book. A 4000 also has 1000 / 540 PTO only the extra 1000 rpm shaft was not shipped with tractor, but all gearing for the dual PTO is in tractor and the same parts as the 4020 . Hope this information is of some help. DW
More Information WTW
10-05-2004 11:41:07
 Re: John Deere 4000 in reply to WTW, 10-05-2004 11:35:51
Forgot to mention that the rockshaft was the same part as the 4020 but three point hitch draft arms were lighter like the 3020 or 4030 tractors used.
Bob
10-05-2004 08:30:36
Go to:
Link
and scroll down to the "4000" menu button.
