I've been around old JD's for more years than I care to remember, but this is a unique dilemma. I have an opportunity to purchase a 620 for $2250, runs nice, probably tired, fresh head job (no rings) straight but rusty hood, bad nose and factory 3ph (minus top link). Does not have float-ride seat ('60' style unit instead) Power steering works OK when tractor is moving, not so good sitting still, oil pressure registers 'low' at idle.The peculiar problem is coffee-brown engine oil, which has intermittant streaks of white when checked on the stick. Usually this is indicative of a leak, but the exhaust does not smell like coolant either right after starting or during operation. Tractor does not push white smoke, either. It leads me to the block, or excessive blow-by. Owner contends the tractor, which sat outside non-operational for a few years, has a buildup of condensation which wasn't flushed when oil was changed. When running, the tractor doesn't seem to fog from the clutch or valve cover vent, but will puff a bit through the dipstick when removed. Long story short, do the 620/630 blocks have a propensity to crack or develop heat stress risers? If the oil were black or tan, it would be a much easier decision. I just don't want to gen into one of those $1,000 rehab projects for a tractor that will only mow a field & plow snow in the winter. Perhaps I'd be better off looking for one in the MW & shipping it back to NY? Any experience with these models would be appreciated.
