730 diesel won't crank
Frank Richardso
10-04-2004 20:44:48
I"m about to start working on an old 730 diesel. I have been told by someone else who worked on it that they couldn"t get it to start. I haven"t tried it personally yet. First off, how are the batteries suppose to be connected? I took the old one"s out and forgot if they were connected in series (+ & - of the batteries connected together) or parallel?
Second, what should I look for? I mean I thought a diesel was pretty simple. I don"t know for certain the year yet. Are there glow plugs on this? I don"t even know where to begin.
buickanddeere
10-06-2004 08:22:18
 Re: 730 diesel won't crank in reply to Frank Richardson, 10-04-2004 20:44:48
Three vent caps means 6V. The previous tinker had no clue about the 12/24V system and got frustrated. Not one but both 12V halves of the 24V system get tapped for 12V positive and 12V neg lights and accessories. There has to be a tie to ground 1/2 way between the batteries. The tractor is not just positive ground. It's 12V+, 12- and 24V isolated from ground/chassis. Get the service ,parts and operator's manuals from 1-800-522-7448 before touching it again. It has to be a 1959 or 1960 model year. There were some 1961's but odds are real slim you have one. Two Cylinder Club can trace the tractor's factory history.
F-I-T
10-05-2004 12:10:58
Frank:
You are about to embark on the repair of a machine which can have a particular voracious appetite for expensive and sometimes unobtainable parts.
You ask "Second, what should I look for?"
I'd saya book. You could call 800-522-7448 and get the official parts and service manuals direct from Deere. Maybe the operators manual as well. That will answer a lot of your questions before you break something worth far more than the cost of the books.
Frank
Bo in Maryland
10-05-2004 14:39:35
 Re: 730 diesel won't crank in reply to F-I-T, 10-05-2004 12:10:58
"You are about to embark on the repair of a machine which can have a particular voracious appetite for expensive and sometimes unobtainable parts."
..... LOL!..... .good one F-I-T!.....I just called my mechanic to put my 730D in his shop for its "annual physical"..... if I had a lick of sense I would have sold the tractor 5 years ago and bought one of those new JD compact/utility models.....but those little models just don't look or sound like a real tractor to me....a 730D is a serious tractor.....if you're gonna get a hoss, get a big hoss.
Good luck to all!
Bo
F-I-T
10-05-2004 15:17:20
 Re: 730 diesel won't crank in reply to Bo in Maryland, 10-05-2004 14:39:35
"...if you're gonna get a hoss, get a big hoss...."
But be sure to read the feedbag!..... ..Ha!
jacob
10-05-2004 10:56:56
There are no glow plugs on the 730. You shoud check the compreshion on the pistons. It also has a positve ground.
CraigE
10-04-2004 23:51:30
Frank, assuming you have a 730 with electric start (not a pony motor) all four of the batteries should be in series so you have 24 volts for starting. There is a tap off of two of them for 12v for accessories. Each battery is, of course, a 6v battery. There are no glow plugs. There is a decompression pedal, a small little pedal on the right side of the gear shift pattern. Put your foot on it while starting to crank the engine to hold the exhaust valves open until you get some rpms going. Then let off of it completely and at same time shove the throttle lever about 1/3 open. If this thing has set for a while, make sure that the hand clutch is free, both the internal clutch discs as well as the little clutch brake pad on the outside of the clutch. If the clutch is free, disengage it by pulling to the rear before you try to start the engine. BTW the starting motor solonoids went out sometimes. It"ll chatter if the batteries are weak or the solonoid is bad. Batteries HAVE to all be good, and all cable connections HAVE to be good, "cause that booger takes a huge current draw to start. But once you get it going, it"s one heck of a great tractor and absolutely defines what the word torque means! Good luck.
Frank Richardson
10-05-2004 09:32:15
 Re: 730 diesel won't crank in reply to CraigE, 10-04-2004 23:51:30
Wow, 4 batteries? I pulled out two huge batteries. I thought they were both 6 volt since they only had three vent caps. Are these possibly two 6 volt batteries in one case? They only had two posts.
720Deere
10-05-2004 10:18:49
 Re: 730 diesel won't crank in reply to Frank Richardson, 10-05-2004 09:32:15
Many people get tired of purchasing 4 batteries and just use two large 12 volt batteries. If they are indeed 6 volt batteries, that would be your problem. It takes good batteries and excellent connections to crank those 24 volt systems. Even with the largest of batteries, they still don't have much cranking reserve in cold weather. Chances are that it won't start below 40 degrees. The pony start tractors used the pony exhaust to heat the intake air for the diesel. They also circulate the coolant through the main engine to bring things up to temperature. Without that extra heat, the electric start just can't cut it.
One more thing. Make sure that the hydraulic pump and the pto are disengaged. You would be surprised how much drag those two items can create.
John Van Valkenburgh
10-06-2004 15:44:55
 Re: 730 diesel won't crank in reply to 720Deere, 10-05-2004 10:18:49
Disengaging the hydraulic pump and PTO are good ideas. If you have to crank it in cold weather you may want to install a block heater and possibly keep the batteries on a float (not trickle) charger. A float charger is designed to be connected all the time and will not overcharge the batteries.
John 1953 Model 50
