60, 45loader hydraulic question-FIT, Clooney?
Fred from MO
10-04-2004 19:26:12
Frank, Clooney. I was reading a bunch of the previous posts and came up with an idea for hooking up my 45 loader to my 60. My 45 loader came with one pioneer fitting on a single hyd line fitted with a regular faucet valve, then this line T-ed off into 2 lines each of wich went to the back fitting on the 45 loader cylinders. If I install this single pioneer fitting on the top pipe plug on the RH side of the power trol port, using the original rock shaft plugs in the Power trol, I should be able to raise the rock shaft first, then the remote cylinders on the loader-Correct? Since the remote cylinders will decompress I will only have power up, and bleed off down-Correct? If this regular faucet valve is in the line like it is, I could raise the remote cylinders on the loader to keep the loader from dragging on the ground, close the faucet valve in essance keeping the loader up off the ground, and still raise and lower the rockshaft withouth effecting the remote loader cylinders since they are essentially locked up with pressure on them. Does that make sense? I want to use a plow or a blade with my 3 point, but yet do not want to remove the loader for this type of operation. What is the advantage for using both the upper and lower pipe ports on the RH side of the power trol for a one way cylinder?
