Front wheel wobble on a G
JDG
10-04-2004 18:38:32
The front wheels wobble on my 1950 split pedastal "G". Wheel bearings appear O.K., worm and sector gear is worn but not bad and eccentric bushing is still round. Ant suggestions?
nigelB
10-05-2004 11:46:43
 Re: Front wheel wobble on a G in reply to JDG, 10-04-2004 18:38:32
If just gone through the complete steering system today on a B(same differance) new steering rod on to old worm,new bottom bush made as you cant get them!new worm bearings adjusted to perfection,shimmed post to take out end float,checked i.d on exentric adjuster was round for a change, then onto the steering gear and i knew i was in for a kickin as usual! "THERE ALL WORE OUT" and to be fair there all 50 years or more old so what should we all expect! as johnT said there wore in the middle they may not appear to be but they are and its enough to get you down! its a case of the best of a bad job or the luck of the draw so to speak. jack the wheels of the ground turn the exentric a bit at a time put in the screw to mesh in the gears untill you loose your full lock to lock then go back a notch and you know thats the best your got. best of luck! if all else fails let one of your frount tires down that works so in told but its a right bodge job! personlly i think some one needs to ring up china and get a container load of new worms and gears so we can all finnish of are JDs of to perfection! regards nigelB
mitchtp
10-05-2004 07:09:23
i replaced the sector gear on my A and that was the problem, steers like a new one now. might try sharps tractor and see if they have a good used one
JDG
10-05-2004 09:41:35
 Re: Front wheel wobble on a G in reply to mitchtp, 10-05-2004 07:09:23
Thanks- How do I get in touch with Sharps Tractor?
MITCHP
10-05-2004 12:01:42
 Re: Front wheel wobble on a G in reply to JDG, 10-05-2004 09:41:35
1-888-6-SHARPS, OR WWW.OLDJD4U.COM FIRST THOUGH TRY THIS GUY, HE'S IN SOUTH CAROLINA, HE MIGHT HAVE A NEW SECTOR GEAR FOR THAT TRACTOR, I BOUGHT A NEW ONE FROM HIM, YES A NEW ONE, OLD DEALOR STOCK, I BET MOST OF YOUR WOBBLE IS IN THAT SECTOR GEAR, MANLY FROM THAT TRACTOR GOING STRAIGHT ALL THE TIME AND NOT USING THE ENTIRE GEAR EQUALLY. THE GUYS NAME IS FRANK LOOPER, AND HIS # IS 864-859-7206. REALLY NICE GUY AND HAS LOTS OF GOOD PARTS. HOPE THIS HELPS SOME
Mark57_420
10-05-2004 06:10:16
I swore the parts in the steering on my 420 were the same way last year. I had it all the way apart and still didn"t see any wear, but I went ahead and replaced the "wearable" parts anyway. Steers like a new one. I suspect these tolerances are a lot tighter than one would suspect.
John T
10-04-2004 20:25:15
JDG, Is there much horizontal fore n aft end play on the steerign shaft??? If so, remove the end bearign cap n remove some of the shim/gaskets to tighten up the pre load on that front bearing. Have you tired to adjust the sector over closer to the worm by rotating the eccentric bushing?? Dont get it too tight there in the middle straight ahead positon, however, cuz then it may be too tight out on the ends then. Other helpful things are matched tires each aired equal and proper adjusted wheel bearings.
Good luck n God Bless
John T
