1929 GP Spark Plugs
Marty Z
10-04-2004 11:16:33
The old plugs seem to be a pipe thread. One is a Wards #1 plug ,, and the other is an Auto-Lite F-11. What is the hottest plug I can get and where do I find them ? What is the correct gap ?
Thanks
Marty Z Curtice Ohio
Duane Larson
10-04-2004 19:21:32
 Re: 1929 GP Spark Plugs in reply to Marty Z, 10-04-2004 11:16:33
Marty Z,
Your GP came with Champion 7 plugs (be careful - Champion later made a #7 plug which is 18mm, and that is what most folks identify a Champion 7 as). The 7 was renamed 31 in September 1929, and when the Champion 33 became available in November 1929, that was a hotter plug and the choice for the GPs. The 7, 31, and 33 are all 2 piece take aparts, which make cleaning much easier. The good news is they are likely still available from Don McKinsey, P. O. Box 94, Wilkinson, IN 46186, but the bad news is they are kind of pricy as lots of folks are looking for them.
Formal heat range info for pipe thread plugs is hard to find, as that concept was identified as useful about the time pipe thread plugs were phased out.
Champion 25 (now 525) or Autolite 3095 are the readily available pipe thread plugs these days.
My rule for plug gaps is the widest gap the magneto can stand for improved idling characteristics - the gap may have to be narrowed to improve starting if the mag is not real hot. FWIW, I run my GPs at 0.045 - 0.050.
Marty Z
10-04-2004 23:08:51
 Re: 1929 GP Spark Plugs in reply to Duane Larson, 10-04-2004 19:21:32
OK--Will check on the champion 525 and autolite 3095. I did call the auto parts store and they had champion 518 ,, and AC C77L in stock.
I found those from an earlier post that you had in the arcives.
Thanks
Marty Z
