1929 GP
Marty Z
10-04-2004 11:10:35
Can't seem to find data in my manuals. How much gear oil does the differential ( main gear case) hold? I can't seem to find the usual "fill to this point" plugs on the side of the case. Is there one ?
Thanks
Marty Z
Curtice Ohio
Duane Larson
10-04-2004 19:29:47
 Re: 1929 GP in reply to Marty Z, 10-04-2004 11:10:35
Marty Z,
The transmission level plug is below and in back of the pulley - just a small pipe plug. I have measured the amount of oil it takes, but the number is in the shop somewhere. The chain housing also needs transmission oil, and the proper level is at the top plug on the outside of the bottom of the case - the bottom plug is for draining the chain housing. The GP owners manual shows the location of the level plugs.
Marty Z
10-04-2004 23:00:01
 Re: 1929 GP in reply to Duane Larson, 10-04-2004 19:29:47
Thanks Duane,
I found the plug you were talking about. It is just to the rear of the first reduction gear cover.. about 4-5 inches from the bottom of the case, and I will pull it tomorrow. I think I put too much gear oil in ... Thanks a bunch
Marty Z
