2520 injection pump driveshaft
megamoodairy
10-04-2004 11:07:37
I recently seized the injection pump and sheared the pump driveshaft. I have a new pump and shaft, but i cannot figure out how to remove the old broken shaft. I removed the access cover on the front of the timing cover, and removed the nut and washer I can't feel anything else holding the shaft in place, but even tapping the shaft with a hammer won't make it budge. Any ideas as i need this tractor up and running asap to unload silage wagons.
msb
10-04-2004 20:35:47
 Re: 2520 injection pump driveshaft in reply to megamoodairy, 10-04-2004 11:07:37
Why did the shaft twist off?If you are not using CO-OP Diesel X fuel I would suggest you us it or at least use soy diesel.Those pumps don"t get enough lubrication from a lot of what is on the market these days.The CO OP fuel is the only sweet crude being refined thses days and it does have the proper lubricating qualities your pump needs.
megamoodairy
10-05-2004 03:37:17
 Re: 2520 injection pump driveshaft in reply to msb, 10-04-2004 20:35:47
The pump siezed because the fuel company delivered about 10 gallons of water with our last fuel delivery. I was unaware of this and filled up the tractor and took off to the field and in about 15 minutes the pump was trashed.
RJ-AZ
10-04-2004 19:51:23
there should be two threaded holes on the gear on each side of the shaft. Make a PUSHER from a piece of 1"X3/16" stock and measuring and drilling two holes to match the spacing. Then drill a larger hole in the center and weld a 3/8" nut to it and use a bolt to push the shaft out the back of the gear. Deere has a (special) tool for this but you can make one in no time at all.I beleive the two small holes are 1/4", the newer Saran engines are metric though.
megamoodairy
10-05-2004 03:41:04
 Re: 2520 injection pump driveshaft in reply to RJ-AZ, 10-04-2004 19:51:23
Thanks. I should have known that Deere would have a special tool for this operation.
Bob
10-04-2004 11:24:39
I believe the pump shaft is tapered, and has a key. You will need to force it out of the gear with a puller.
