JD 1010 throttle lever replacement
lloyd, sc
10-04-2004 10:44:07
Bush hogging & got into a tree, bent throttle lever. Not available from JD. Bought a 1/2 " X .120 steel tube. .20" too big so chucked it in a drill press & used up most of a cheap sharpening stone to cut it down. Then had to chuck & grind (stop unlock lever) rod as it was too large to fit through new tube. Managed to end up with better than original for under $5.00. Not all that often that happens!
