2010 gas-Dare I buy it?!?!?
WeirdDeere
10-04-2004 10:16:37
I'v looked through the archives, but I appreciate any comments.
There is a 2010 gas just down the road from me with all the features we need for a "work" tractor (3pt, 1 set of remotes, power steering, wide front). They want $3500 for it. I'm hoping to get it a little cheaper, one rim is a bit on the rusty side, and the tires will last a while, but definitely aren't new. It looks pretty good (a recent repaint), but that doesn't matter. Of course I need to hear it run, and drive it around, make sure everything works, etc!!!
Anything I should look out for? I've heard of the sleeve deck sealing problems, but weren't these mostly diesel problems and not gas? In any case to see if the sleeve deck is bad...just look out for water and oil in the wrong spots? Any other notorious problems?
Were they 12 volt originally (positive or negative ground?) It has an alternator now. I'm just curious.
Thanks,
Brandon
Mike M
10-06-2004 18:50:05
 Re: 2010 gas-Dare I buy it?!?!? in reply to WeirdDeere, 10-04-2004 10:16:37
You say you need a work tractor. You could buy a 620 for that much. Or spend a little more and move up to a 1020,1520,2020 well worth the upgrade.
Steve R
10-05-2004 18:53:24
My dad had a 1962 2010 tractor. Just like the things you heard before ,it was the biggest piece of JUNK I've have ever been around! It would not pull the 3/14 plow,the 8ft. disk, or the 5ft. brush hog
without laboring and overheating. It seemed like every time we left on it we either walked home or had to work on it. My grandpa traded a John Deere
40 in for this tractor in hopes of upgrading . But all he did was go backwards. I myself would Never buy a 2010 , and I love John Deere. Steve R
ET
10-05-2004 08:29:04
The row crop utility was the better model. If you get a good one you can't break it, but if you get a bad one you can't fix it!
Duane Larson
10-04-2004 19:37:14
Brandon,
My Dad traded in a 50 for his 2010 gas in 1963, and it was his farming tractor until 1984 when he retired. It pulled a 3-14 plow, 2 row New Idea corn picker, #30 combine, etc. One overhaul and one valve job - tires, plugs, oil/filter changes, ... - but other than that a good tractor. So apparently there were at least two good ones out there. It had a 12V generator.
farmergreen
10-04-2004 14:50:27
Currently maintaining a gasoline 1962-63 2010 that has been in the family for over 40 years. I've read much of the negative chatter about the 2010 being the worse tractor manufacturer by Deere. What I can tell you is that it has been s solid workhorse pumping out 47 PTO hp with 145 cu in engine. It dealt easily with some very big trees Hurricane Ivan threw at it and operated a six foot cutter with no problems. Here is one solid suggestion. Don't raise an implement on the 3 pt hitch too high and bounce along a bumpy road or field. The rockshaft arms can hyper-extend upward with a heavy load and crash through the rockshaft housing disabling the hydraulics. There is no brake or block to stop the upward motion in that type of situation. As with any tractor, keep it well lubricated. Ours just developed a leak around the PTO shaft which I believe was caused by sitting idle for one full year due to the rockshaft problem described above
