420W Front Axle Slop
Andy
02-06-2004 04:00:00
My 1956 420W with adjustable wide front axle has a lot of slop at the pivot point. I was told there was a bushing in the axle for the pivot. It looks like mine has been long gone. I was wondering if this is the case and if anyone has a part number for the bushing so I can tighten the frontend back up. Thanks...
Dave- Ia
02-06-2004 08:35:40
 Re: 420W Front Axle Slop in reply to Andy, 02-06-2004 04:00:00
WhenI replaced that bushing on my 430 W last winter the casting was worn a little. I used it that way during the summer and it started to work out again. I used some lock tight made to hold bearings in place on a shaft and it has stayed in place since.
Phil - MO
02-06-2004 05:46:57
Your local JD dealer should have it.
I replaced the sleeve on my 430, and it worked out and disappeared. I added a large washer to hold the second one in place.
Phil
Wayne in Tn.
02-06-2004 06:24:40
 Re: Re: 420W Front Axle Slop in reply to Phil - MO, 02-06-2004 05:46:57
Andy, your front support will have two bushings that can be replaced. The front one is # M3292T The rear one is # M1111T It is also possible your pin or the housing itself is worn, and just replacing those bushings may not be all you need to do.
CFW
02-07-2004 10:22:19
 Re: Re: Re: 420W Front Axle Slop in reply to Wayne in Tn., 02-06-2004 06:24:40
Wayne you said:
It is also possible your pin or the housing itself is worn, and just replacing those bushings may not be all you need to do. If the housing is worn is it repairable and how would you accomplish that. My JD M has the same problem but I think the bushing is one piece....will have to look in the parts book. I am thinking I checked on the JD parts site and they do not carry the bushing for the M. Is there a company that specializes in bushings? Thanks
