4010 brakes locked up
PUTTER
10-04-2004 09:27:27
I was using my 4010 yesterday and the right brake has locked up, i managed to get it back to the barn but don't really know where to start. They had been working fine. Any help would be appreciated. Thanks PUTTER
WTW
10-04-2004 10:50:53
 Re: 4010 brakes locked up in reply to PUTTER, 10-04-2004 09:27:27
Putter, If brake pedal did not return all the way up the plunger that activates brake valve is stuck down in brake valve housing usually due to rubber boots rotted out, allowing water to enter this area and rusting plunger. Nothing a kit, rubber boots and some shop time won't fix. If pedals seem to be in there normal position, disconnect brake lines at rear final drives and start tractor to see if brake line on side with problem is flowing oil from it. If it is there is a problem in brake valve, if not try to move tractor, if tractor brake is still locked with brake lines disconnected problem is in brake / final drive assembly and will require final drive removal for inspection. Good Luck, DW
