430W Power Steering
J Bennett
10-04-2004 08:19:58
I have power steering fluid leaking past the power steering cylinder head into the steering gear. Can I take the cylinder off without removing the rack and pnion and replace the o-rings in the cylinder head? Thanks, J Bennett
Henry J
10-04-2004 19:18:09
 Re: 430W Power Steering in reply to J Bennett, 10-04-2004 08:19:58
J
I just looked over the pictures and it appears to me that you could approach it that way. One thing is that it could also be leaking along the shaft from the piston that goes through the cylinder head.
It may have to be turned enough in the correct direction to get the rack to extend out far enough for the pin to be removed from the rod to free the whole assembly. Maybe that has to come off so you can replace the o ring in the center of the cylinder head.
A note. I can't give you all the engineering aspect of timing the rack and pinion but the book says if the rack gets out of the pinion it has to be timed with the pinion when put back in and I don't think you can do this if the rack says oops and slips out entirely.
Might be a good time to consider honing it and re ringing it also.
Good luck
Wayne in Tn.
10-04-2004 18:20:48
J Bennett, I have never worked on the power steering on the Dubuques, but I recently bought a box of small parts for those. If you have the part number of what you need, I may have it. The parts are NOS still in the original packages. My e-mail is: [email protected]
