Breakaway coupler leaks
Lincoln
10-04-2004 07:45:37
The breakaway coupler on my 3020 leaks. It appears to be comming from the levers on the bottom. I see JD offers a repair kit for about $19.00. Would this cure my problem? Is it difficult to rebuild one? Thanks.
jd4960
10-04-2004 09:14:47
 Re: Breakaway coupler leaks in reply to Lincoln, 10-04-2004 07:45:37
just be careful when you pull the barrel out the retaining balls in the barrel have a nasty habit of going every where I usually hold a shop towel under the barrel to catch them. Bob is right about the barrels where the pin goes thru one side is flat the other rounded you want the flat side up. takes about 15-30 min. per barrel.
Bob
10-04-2004 07:55:13
Yes, the kit should fix the problem. It's not too difficult to install, except for 2 snaprings that restrain 2 little springs.
Pay attention to the orientation of the coupler barrels, and reinstall them turned the same way.
