3020 Oil Line ?
Lincoln
10-04-2004 07:42:23
On my 1966 3020 gas there is a small (1/4 inch perhaps) plastic oil line running from the bottom of the hydraulic pump to a Tee fitting back by the brake lines. What is the line for? Is it supposed to be plastic tubing? Mine has been spliced in several places and I want to replace it with the correct stuff.
G-MAN
10-04-2004 07:54:52
 Re: 3020 Oil Line ? in reply to Lincoln, 10-04-2004 07:42:23
That's the hydraulic pump oil drain line, which allows excess oil to make its way out of the pump seal area. Your dealer can set you up with an new line. It will be plastic and preflared on both ends with new nuts already on it. I can't recall for sure, but the new one may be larger and require an adapter fitting at each end.
Bob
10-04-2004 07:52:42
There are two seals in the hydraulic pump, an inner "QUAD RING" that"s the actual seal, and then a lip seal visible from the outside, surrounding the pump shaft.
The plastic line is a "weep line" that is plumbed into the chamber between the two seals and returns oil to the transmission sump. When the pump is in good condition, little, if any oil leaks from the primary seal, and through the "weep line" back to the sump. As the pump bearings and primary seal wear, and some oil begans to leak past the primary seal, the line carrys it away, preventing any oil from leaking out the secondary seal. If there is more bearing wear, or the primary seal fails, the flow of oil will overwhelm the capacity of the "weep line", and will leak out past the secondary seal.
The older units had a small steel line, and often they would leak because of a hole worn in them by vibrating against something, or because of rust-through. The Deere replacement lines are plastic, and a larger diameter, probably for easier flow, and less oil pressure against the secondary seal.
The plastic line is part #AR87534, and lists for $15.75. If the tractor has NOT had the larger plastic line installed previously, there is an adapter fitting needed for each end, #R64170.
