JD 2010 very strange fluid loss
farmergreen
10-04-2004 07:28:04
The replacement of the rockshaft housing appeared to be successful. Rockshaft arms had solid lift capability and holding power. Used the tractor for a day hauling trees without using the three point hitch. Finally hooked up the bush hog. It raised and lowered perfectly. Ran out of daylight, put it back in the barn to cut another day. The PTO always worked and still works. Backed it out the barn yesterday. Noticed power steering and rockshaft not working. Fluid looked low, refilled, but then heard fluid pouring beneath the tractor. Both hydraulic drain plugs intact. Found a 1/4 inch hole right above the drawbar where fluid was streaming out, not leaking. The hole is right in the center of the transmission case about 8 inches rear of the rear drain plug and is supposed to be there. I removed the drawbar and let the fluid drain out. The hole is not threaded and the appearance gives no indication it held a plug or bolt. Found a similar hole a few inches in front of the front drain plug. If you insert a small screw driver in the front hole, you can only insert it about an inch and you hit metal, but if you insert the screwdriver in the streaming rear hole, the screw driver will go up into the transmission case as far as you can insert the screwdriver. I can't figure out why all of sudden this hole has opened up and allows all of the hydraulics fluid to stream out. My solution is to plug up the hole, but I'm concerned about why this started. As far as I can tell, the chamber above it is full of gears and is supposed to be lubricated. Above the gears is the valve control housing which is part of the rockshaft assembly. Any help will be greatly appreciated. I have the 700 page repair manual and parts manual, but I can't find anything to help on this question.
Joe Stewart
10-04-2004 15:21:20
 Re: JD 2010 very strange fluid loss in reply to farmergreen, 10-04-2004 07:28:04
I replaced my PTO shaft seal on my 2010 row crop about a year ago. It was leaking hydraulic fluid from that same hole. Those weep holes usually have a cotter pin stuck through them to maintain patency. The hole leads to the pto clutch housing, which of course, is normally dry. The replacement of the seal took me about 5-1/2 hours total work time. You have to remove the rockshaft housing (requires an overhead hoist or engine crane) and the PTO housing, then the PTO clutch, then pull the PTO shaft out the rear and replace the seal. Not as bad as it sounds. Follow the instructions in the manual when you remove the rockshaft housing, so that you do not forget to unscrew those two bolts that hold the rockshaft hydraulic supply tube. If you skip that step, you will snap off or bend the hydraulic supply tube when you lift the housing. Good luck. Joe Stewart
farmergreen
10-04-2004 14:47:49
Sadly, I found the answer in the repair manual. It reads, �To reach the powershaft clutch and linkage, remove rockshaft unit from tractor.� Not what I wanted to hear. Substantial time will be involved in reaching the likely culprit, a worn out oil seal around the PTO shaft.
Bob
10-04-2004 08:03:53
If I'm understanding you correctly, that hole in the case is a "weep hole" or drain at the bottom of the PTO clutch housing, which is a the rear of the tractor. You may have seen it from ther top, when you had the 3-point cover off. There isn't supposed to be any oil down there. (The PTO clutch is "DRY".)
You have a leak at the bottom of your 3-point top cover assembly, or possibly a bad PTO shaft seal.
farmergreen
10-04-2004 08:24:27
 Re: JD 2010 very strange fluid loss in reply to Bob, 10-04-2004 08:03:53
I was afraid it was something like that. The fact that the tractor setup almost a year with a broken rockshaft housing and the PTO not being used must have created a problem waiting to happen once the PTO was engaged. It sounds like once it was engaged, the seals or bushings around the PTO shaft must have given way. That would also explain why their is fluid leaking from around the lower (1000rpm) PTO. The sudden onset would have to be attributable to a PTO problem. Do you know if this can be repaired by removing the the rear PTO housing or will another breakdown and removal of the whole rockshaft assembly have to be undertaken?
Bob in Buffalo
10-04-2004 17:43:13
 Re: JD 2010 very strange fluid loss in reply to farmergreen, 10-04-2004 08:24:27
Hello, Yes, I am sure your pto seal is bad. Readily available from Deere and not a real big deal to replace. You DO NOT have to remove the Rockshaft unit from the tractor. I just did the same job a month ago while replacing another broken roll pin (they use them alot on the pto setup including linkage and they seem to be aweak link in the setup). Also plan on replacing the two outer pto shaft seals on the outside while you are at it, and the main gasket for the housing. All the parts cost me around $32.00 from Deere. You can remove the PTO housing , balance the unit on a jack, and remove the two cotter pins and pins for the linkage and it will come right out. Alot easier said than done, but it will work. I pulled it apart in an hour, and took a couple hours to reassemble the housing and re-install it on the tractor. Any questions, let me know.
Bob
farmergreen
10-05-2004 07:12:04
 Re: JD 2010 very strange fluid loss in reply to Bob in Buffalo, 10-04-2004 17:43:13
According to the repair manual, you have to remove the rockshaft assembly to access the PTO clutch housing. Didn't receive your message until this morning, but I'm glad I read it late. By removing the housing I discovered one of the new snap rings on the valve housing had dislodged and that's where all of the fluid came from. I checked the other snap rings on the valves and found one more had started to move. I located two of the old rings that I had pulled out, and reinserted those. I think the thickness of the new rings were ever so slightly too thick. There is an indention they seat into, and it appears some of those indentions are worn and some of the new snap rings didn�t fit as snugly into those indentions as they needed to. Now that the source of the fluid had been stopped, do you think it is necessary to replace the seals at this time?
Joe Stewart
10-06-2004 05:00:39
 Re: JD 2010 very strange fluid loss in reply to farmergreen, 10-05-2004 07:12:04
I would replace the seals while you have it apart. This includes the pto shaft seal on the back of the transmission case and three seals on the pto case itself (one input and two output). The seals you have now may be 40 years old.
