JD 4040 powershift
Tx Jim
10-04-2004 05:30:18
A friend was driving a 4040 PS,stopped it for fuel and now it won't move.Changed hyd.filters,checked sump screen,checked trans.pump pressure,all OK.Still won't move.Any ideas.Could it be the foot clutch valve?Thanks,Tx Jim
G-MAN
10-04-2004 07:56:40
 Re: JD 4040 powershift in reply to Tx Jim, 10-04-2004 05:30:18
Twopop is correct. Check the tow disconnect first. It's pretty hard for one to jump into tow by itself, but probably possible and the easiest check to make.
Tx Jim
10-05-2004 04:58:15
 Thanks for repies in reply to G-MAN, 10-04-2004 07:56:40
Disconnect is not problem because friend got it to move once under it's own power.I will ask if trans.light has come on.Thanks,Tx Jim
twopop
10-04-2004 07:01:46
on the left side of the tractor,under the cab,there is a lever that takes the trans out of gear.it lets you tow the tractor. there is a possibility that someone moved it.
Txsprigger
10-04-2004 05:41:47
Does the trans light stay on? Had a 4440 stop dead in middle of the road, wouldn't move, trans light stayed on, transmission was totally shot.
Hope this is not the case for you.
