Something strange on fresh engine rebuild.
44 JD Model B
10-03-2004 20:47:25
1944 JD Model B After I have started and warmed up engine I can pull the spark plug wire off the left cylinder and it runs fine on the right cylinder alone.
With both spark plugs attached, I can open the compression relief valve while engine is running on the left cylinder and I get the normal exhaust gas.
When I open the compression relief valve on the right cylinder no normal exhaust gas, there is no explosion of fuel.
If I pull the spark plug wire off the left cylinder, the tractor will then start running on the right cylinder by itself. I can open the compression relief valve and now it has normal exhaust gas.
Robert's Carburetor rebuilt my carburetor and magneto. I have readjusted the valves to make sure they were not to tight. It has new spark plugs and wires.
Anyone ever heard of this?
twopopper
10-10-2004 06:38:33
 Re: Something strange on fresh engine rebuild. in reply to 44 JD Model B, 10-03-2004 20:47:25
My B done the same thing until I put a 1-20 lpow behind her 10" deep in heavy clay. The front only touched the tops of the weeds the hole time it was in the ground. Have a blast and enjoy as all have said!
AcE
10-04-2004 19:49:12
Sounds like a typical 2 popper with a single barrel carb to me. Hit and Miss, The harder ya pull them the less they miss.
Greg S
10-04-2004 11:29:55
I have a freshly rebuilt B that was manufactured in 1944 that does the same thing. There are several factors contributing to this, but the bottom line is that this behavior is quite normal.
Rockin' Farmer
10-04-2004 07:44:46
Sounds normal at idle. Under load he should run evenly on both cylinders.
Enjoy,
Rockin' Farmer
twopop
10-04-2004 07:06:35
i believe you should check the magneto cap.i think the cap is cracked.
JDMark
10-04-2004 05:27:02
44B,
Have you done a compression test yet? Are these symptoms just during idle? It's not uncommon for both cylinders not to hit at idle. The #1 cylinder is the dominant cylinder 'cause it hits first, then #2 fires 180 degrees later. There is a certain amount of "unevenness" in this system because of the design of the manifold, the single barrel carb, & the firing pattern. This isn't the case with the newer tractors with a duplex carb, where each cylinder has it's own fuel supply.
Mark
Bob
10-04-2004 07:07:35
 Re: Something strange on fresh engine rebuild. in reply to JDMark, 10-04-2004 05:27:02
Good explanation, Mark!
44, welcome to the "Poppin Johnny" club!
Now you know how they got their name!
Mike in New Mexico
10-04-2004 08:55:28
 Re: Something strange on fresh engine rebuild. in reply to Bob, 10-04-2004 07:07:35
Reminds me of my first John Deere- an unstyled A,
I wasted a lot of money and time trying to get her to run smoother! Then one day my wife set me down and told me that 'maybe I was trying to "take the pop out of Johnnie Popper"--she was right !! and she had never been around tractors be fore !! just enjoy your tractor!-mike
Bob
10-04-2004 10:41:16
 Re: Something strange on fresh engine rebuild. in reply to Mike in New Mexico, 10-04-2004 08:55:28
You must have quite a wife, YOU LUCKY DOG!
Mike in New Mexico
10-05-2004 08:52:25
 Re: Something strange on fresh engine rebuild. in reply to Bob, 10-04-2004 10:41:16
I met, dated,and married my wife in less then 30 days ! next week we will celebrate our 33rd anniversary !! yeah, I got lucky !! -mike
