3010 propane ignition
laborintensive
10-03-2004 15:47:54
I"ve got a 1962 3010 Lp that is positive ground and am thinking of converting it over to electronic ignition. Does Pertronics (sp?) make a kit for it being a POS. ground or should I switch it to a NEG. ground? What is involved if I need to change it? What about leaving it on the generator setup or switching to alternator?
The little tractor runs well once it gets going, I"m just thinking this winter its going to be hard on batteries. Thoughts and suggestions welcome! Thanks much.
Gerald J.
10-03-2004 18:01:24
 Re: 3010 propane ignition in reply to laborintensive, 10-03-2004 15:47:54
Switching polarity is easy. I wrote about it on this list in the past week on my 4020 gas.
You need to switch the battery connections, that may take some new cables since the posts are different sizes to keep that switch from being accidental. You need to swap the ignition coil primary terminals (+ to supply - to distributor). You need to flash the generator before starting again to reverse its polarity. Hook a wire from Bat to ARM or GEN on the regulator for a second or two. Its switched.
An alternator is nice because the generator is really wimpy only 20 amps and takes a long time to charge the battery after a cold start.
There are lots of parts in an electronic ignition so fail, only three or four in the points, though the points get more mechanical work. I just lubricated my distributors and starts seem to be better. 10 drops of oil under the rotor for the centrifugal advance. One drop on the point pivot, and a smear of disk brake wheel bearing grease on the cam.
I don't know about the '10 but my 4020 shop manual shows a wiring resistor on the coil with a contact on the starter solenoid to short out that resistor for starting. A ceramic block resistor and copper wire has replaced that. I didn't have trouble last winter down to 20, didn't need the tractor in colder weather.
I do have an alternator and new by battery life is greatly extended. I'm also using a sealed side terminal battery mounted on a new step close to the starter. I added a second step half way to the ground to make it easier to get on the tractor.
Gerald J.
laborintensive
10-04-2004 14:05:35
 Re: 3010 propane ignition in reply to Gerald J., 10-03-2004 18:01:24
I really had thought the electronic ignition would be much less prone to failing!
Tell me, why did JD use a + ground? Whats the purpose? I suppose if it works just as well I could just leave it well enough alone.
Bob
10-03-2004 22:20:04
I am an advocate of 12 Volt, negative ground systems, with an alternator.
Be aware, however, that sometimes the electric fuel gauge may not be accurate after a polarity swap.
If you have any questions about what Pertronix ignitions are available, or part numbers, visit their website:
www.pertronix.com
You'll find contact information there, email or phone. The customer service people are helpfull and knowlegeable.
