Cameron
10-05-2004 11:14:58
Re: Bicycle. in reply to Thomas Beale, 10-03-2004 12:20:38
Tom, I know that JD came out with bicycles a couple different times. The second time was in the mid 70's. They had the 20" boys and girls high rise handlebar with banana seat in yellow, the 26" three-speed in JD green, a white 5-speed mixte, and the black men"s frame 10 speed, 26 or 27". I"m not sure who manufacturered them, and most of my experience was with my 3-speed that I got new in 1975. Components and frame were good quality, as the frame on the 3-speed was brazed and had lugs at the frame connections. It had Shimano gears. Not sure about the crank and brakes, except that they were steel, and the crank arms used the key-pin at the crank. Wheels were steel. Quality would be similar to that of a Raleigh (British - very good). Schwinn did not make a similar brazed frame that I have seen, as theirs were more welded. As far as being a collector"s item, the fewer of them that there are, the value will go up, if someone is looking for them. In the same respect, Artic Cat put out bikes also in the early 70"s. From looking at them, it looks like a Peugeot (French) style with similar components. The japanese bikes came on more in the mid 70"s, taking over the mid-priced segment away from the French, and replacing the French and German components with Shimano and Sun-tour. The Italians retained the high-end. Good luck. Cam
