430 governor
Hayfarmer
10-03-2004 09:57:06
Do the governor springs on these get streached over time and not allow it to work properly? I know with my IH SMTA the internal spring makes a lot of difference in keeping RPMs up when a load is applied, wondering if these Dubuque tractors are similar only with outside spring?
Wayne in Tn.
10-04-2004 05:38:49
 Re: 430 governor in reply to Hayfarmer, 10-03-2004 09:57:06
Hayfarmer,it is possible for the gov. to give problems. But I have never owned one that the gov. was the culprit. You don"t say what the problem is, but if it is "searching" then its doing its job. The usual problem on the Dubuques is the carb. or worn holes where the linkage connects. Usually a carb. rebuild, throttle shaft and seals will stop the problem.
