Bad gas and junk in the gas tank
Marc Weymouth
10-03-2004 07:24:36
I found out what was wrong with my 160 lawn tractor. I had some water in the tank and It has alot of junk in it. What is the best way to clean the inside of the tank? The tank is removed already!!
truckman21
10-03-2004 20:04:21
 Re: Bad gas and junk in the gas tank in reply to Marc Weymouth, 10-03-2004 07:24:36
A friend that works on mowers and tractors would put some gravel in the tank and shake it around for a while to loosen the rust scale, then dump it all out and rinse it out a few times. I haven"t tried it, but I know he has done it many times.
Pete/ME
10-04-2004 02:48:14
 Re: Bad gas and junk in the gas tank in reply to truckman21, 10-03-2004 20:04:21
Probably want to add some detergent and water, wouldn't want a spark to set the thing off.
Tim...OK
10-04-2004 06:11:34
 Re: Bad gas and junk in the gas tank in reply to Pete/ME, 10-04-2004 02:48:14
I add maybe a pint of diesel,then shake..ever tried to make diesel ignite?? Hard enough to get lit when you want it to burn,works good.
Tim
