JD 4020 engine swap
JDG
10-03-2004 06:33:59
Will a 4020 diesel engine bolt directly in a 3010 gas travtor? If alterations are needed, what are they? How do the gears match between a 4020 diesel tractor and a 3010 gas tractor?
Many multiple questions, I know but I really need the advice.
Thanks, JDG
JDG
10-04-2004 06:30:24
 Re: JD 4020 engine swap in reply to JDG, 10-03-2004 06:33:59
Thank you all for your conversation and advice. This is exactly what I was hoping for. Since I don't know what is involved in this swap or how these tractors match up I relied on you all to help. And you did.
Consideration of this project is scrubbed!
Thanks Again,
JDG
ol George
10-04-2004 18:02:08
 Re: JD 4020 engine swap in reply to JDG, 10-04-2004 06:30:24
Sorry, I think you would have been pleasantly suprised if you had went ahead and done the swap. The two I have done are working great and the owners are extremely happy. 1) it is now a dsl and 2) it pulls his disc mower without the lugging and choking they had before. TEHO
mechanic
10-04-2004 06:12:04
 Trade the tractor for a 4020! in reply to JDG, 10-03-2004 06:33:59
This project is a no go.
Stuart
10-03-2004 20:48:59
You cannot even began to understand how much work it is
T213R
10-03-2004 14:22:04
So, what you are attempting to build is a 4000? You will need a new hood and frame rails for sure!
buickanddeere
10-03-2004 16:27:31
 Re: JD 4020 engine swap in reply to T213R, 10-03-2004 14:22:04
A 4000 uses a 4020 and 4010 rear end parts. Nothing to do with a 3010/3020.
T213R
10-03-2004 20:05:26
 Re: JD 4020 engine swap in reply to buickanddeere, 10-03-2004 16:27:31
I know what a 4000 is perfectly well. The 3010 rear end is a LOT lighter, but putting a 4020 engine in one would STILL be similar, if much more extreme, to a 4000! My bet would be that this combintion, if attempted, would result in a tractor that would easily destroy it's own rear end and transmision if used for much of any kind of lugging. I wouldn't try lugging the pto either!
buickanddeere
10-04-2004 09:20:20
 Re: JD 4020 engine swap in reply to T213R, 10-03-2004 20:05:26
Sorry. If you check the parts books the 4000 & 4020 differ in the transmission/final drive only a little. No syncromesh into reverse and the final drives are mostly 4010 parts with the stepped down dia rear axle. Parts common with the 3020 are few and minor in nature.
T213R
10-04-2004 16:22:42
 Re: JD 4020 engine swap in reply to buickanddeere, 10-04-2004 09:20:20
My point was, this person was considering the attempt at "building" a tractor which would share the same concept as a 4000, but with weaker parts! Nowhere was I insinuating that the 3010 shared anything in common with a real 4000.
Another view of this project is that the resulting tractor would be something like but not exactly like one of those Funk V8 engine conversions done to an 8N Ford. (100hp engine in a 25 hp chassis is how I've heard that tractor discribed)!
There is also a picture (on page 87) of Beemer's book on NG tractors, of a formerly gas 3020 which recieved a 6239 engine (claimed 105hp no less)!
WTW
10-04-2004 10:20:26
Better check your parts book again as mine does not show any 4010 final drives parts common to a 4000. A 4000 final drive has (some) parts common to the 4020 like the input shaft, ring gear and planetary gears. No 4010 parts other than maybe a bearing. Axle and carrier parts are unique to a 4000.
ol George
10-03-2004 07:21:16
It will directly bolt to the rear end housing, then it gets interesting, longer hydraulic lines, either 4020 frame rails or lengthening the 30's, if you use the 3020 flywheel you will have to change the starter drive to a dsl starter. There are some more things that I discovered but I am not going to type it. Let me know if I can help.
