JD 1010 electrical problem
BudJenn
10-03-2004 04:14:39
I just bought this 1010. Been setting a couple years and the owner put the battery in with neg. ground. He jump started and it sounds good. When getting it home I reversed the battery and put in new point. Don't know why but tractor now wont start and the coil melted down. Put in new coil and it heated up right away without even turning switch on. Should I reverse the battery back to Neg. ground? Thanks, Bud
John T
10-03-2004 16:47:23
 Re: JD 1010 electrical problem in reply to BudJenn, 10-03-2004 04:14:39
Bud, before addressing the reversed polarity issue, lets try n finger out why the coil is heating up EVEN WITH THE IGNITION SWITCH OFF?? You gotta have power to it PLUS the points closed (but are usually anyway) or else a shorted condensor or shorted wiring to heat it up.
1) For that to happen: (A) the points must be closed (or the wiring or points are shorted to ground somewhere) HOWEVER, they are normally and usually closed anyway, since they only open when the coil fires which is at TDC of a pistons stroke and they cant/wont hardly stop there when you shut a tractor down anyway. And (B) there must be power on the coils high input side, even though its normally not there unless the switch is on. You may wanna check for points wiring shorts or if theres any short where the points wire passes through the distributor via an insulated terminal (it may be broke n shorted out) ALSO, if a condensor were dead shorted (or its wires) its like the points never open n the coil gets warm and the tractor wotn start!!!!! !
2) So we cant say yet for sure if theres any points problem (I hope n assume for now they open n close and are gapped proper??? check that out, rotate the distributor n see if they open n close and ARE NOT SHORTED OUT NOR THE WIRES TO THEM SHORTED OUT), so the switch must be bad or theres a short in the wiring which has a constant hot feed shorted to the wire from the switch down to the coil.
3) Remove the coils high input supply wire and use a test lamp and trace back towards the IGN output switch terminal and see why its always hot (even with switch off) and you ought to be able to determin if another wire is shorted to it or the switch is bad. If you remove the wire at the switches IGN output terminal and place a test lamp on it and turn it on n off you can test the switch.
4) Are you sure you have the correct voltge coil??? If you place 12 on a 6 volt coil, they heat up pretty hot pretty quick?? Im insure if the tractor uses a 6 volt coil and an external voltage dropping ballast resistor or what.
On the reverse polarity, you may have damaged the Voltage Regulator or its cutout relays points may be bad/stuck BUT THERES ALSO A CHANCE ITS OKAY. Get the battery wired back correct and try n polarize the Generator n see if it sparks n polarizes okay. Then, find if the points are shorted,,,,, ,,or the condensors shorted,,,,, ,,,or the points or condensor wiring is shorted,,,,, ,,,,, ,if theres any shorts to the distributor or the pass thru insulated stud terminal out the distributor,,,,, ,,,,, then test the switch and wires from it to the coil for a shorted wire or a bad switch,,,,, ,,,,,then get her running (by fixing the short or wires or switch etc) n see if she charges okay,,,,, ,,,,then make sure when she shuts down the ammeter dont show a heavy discharge, cuz if so, the VR cutout relay points may be burned shut.
Let us know
Good Luck n God Bless
John T
F-I-T
10-03-2004 11:23:41
Disconnect the lead to the distributor and see if the coil is still hot. If not, I think you have the ignition points setting closed all the time, so no spark, no run, and that makes the primary of the coil overheat.
Does it have an ammeter? If so, what did it read when it WAS running?
Frank
Bob
10-03-2004 12:39:06
 Re: JD 1010 electrical problem in reply to F-I-T, 10-03-2004 11:23:41
F-I-T,
If I'm reading his post correctly, and the coil is getting hot without the ignition switch even being turned on, he's got more problems than just closed points!
F-I-T
10-03-2004 13:13:46
 Re: JD 1010 electrical problem in reply to Bob, 10-03-2004 12:39:06
Sorry Bob! Missed that line about the switch not being on. Nevertheless, he needs to remove all the "Hot" leads and isolate each one. A stuck VR would only cause a draining battery, so it must be main switch related. Hot to the distributor all the time should be pretty simple to find. Time to use the test light!
Thanks for the correction.
Frank
Bob
10-03-2004 09:28:58
The coil should not heat up, nor should there be any voltage to the coil with the ignition switch off.
Here's my guess as to what happened:
You CANNOT switch battery polarities willy-nilly like that, without asking for trouble!
Anytime a machine with a generator has sat unused for a long time, or has the battery polarity switched, the generator needs to be polarized before startup. This creates a residual magnetic field in the generator of the correct orientation for the generator to charge upon startup, with the polarity matching that of the battery.
Procedures for polarizing a charging system vary, depending if the charging system is a so-called "A" system, or "B" system. Since this tractor's Delco generator is an "A" system, all that is needed is to momentarily touch a jumper wire between the "B" (BATT) terminal on the voltage regulator to the "A" (ARMATURE) terminal on the voltage regulator (sometimes labeled "GEN") before starting the engine.
Back to what I suspect happened... When to tractor was started with the battery polarity reversed, the generator came up to speed and began charging, with the polarity opposite that of the battery. As the generator output voltage came up, the points in the "cutout" section of the voltage regulator closed, connecting the generator, which was charging one polarity, with the battery that was connected in the opposite polarity.
When this happens, the battery has a lot more amperage capacity than the generator, so the battery overcomes the generator's weaker output, and the polarity of the generator "flips" to match that of the battery. So far, so good. The generator is then actually back to charging the battery.
Where the problem comes in is at engine shutdown.
The "cutout" points in the voltage regulator are the losers in the "power struggle" between the generator and the battery, and weld together, When the engine is shut off, the welded points cannot open, and the battery discharges through the generator, likely burning out the generator, and melting the insulation of off wires in the wiring harness. Upon inspection, you will likely find burned wires in the harness, causing a short between an "always hot" wire in the charging system, and the wire to your ignition coil, as the wires to the generator and coil run together in the same harness, causing the coil to have power even with the key switch "off". There may be a resistor to limit power to the coil that is being bypassed by the coil, also, causing even faster coil heating!
You will need to inspect the wiring harness for obvious damage. If the wires inside have melted insulation, there will likely be places where the outer wrap on the harness shows evidence of the damage inside. Unwrap the harness, and repair it by replacing the damaged wires inside, or replace the harness. The harness is likely still available from Deere. There are 3 or 4 used depending on serial number, and cost between $90.00 and $150.00. If you would care to post back with your serial number, I can get a part number and exact price for you.
Have the voltage regulator and generator checked at a good local automotive electrical shop. One or both will likely need to be replaced.
Most likely, the ignition breaker points will need to be replaced, also. Hopefully, your new coil has not yet been damaged! (Be SURE the new coil is correct for this application.)
Good Luck! Please post back, I'd like to know if this scenario is what happened to your tractor!
