Brass Tags
foggman
10-02-2004 23:07:25
Can someone tell me what the difference is between a brass tag tractor and a steel tag tractor
Bus Driver
10-03-2004 18:05:58
 Re: Brass Tags in reply to foggman, 10-02-2004 23:07:25
I do have a brass tag 35B in need of lots of TLC. The brass tag (not the rest of the tractor) generally stays in the best condition over the years. My tag is the only perfect thing on the tractor.
Maark
10-03-2004 06:12:14
The first JD tractors used brass material for the serial number tag until late 35 or early 36. JD then used aluminum until ww2 when aluminum became scarce. Steel was then used until the war was over when JD went back to using aluminum. I believe JD started using brass with the 20 or 30 series tractors again.
Bob
10-03-2004 10:01:17
 Re: Brass Tags in reply to Maark, 10-03-2004 06:12:14
I've always wondered... was each change of tag material run thoughout a whole series of serial numbers, or was there an occasional brass tag used in the middle of a series of steel tags?
My understanding has been that there would NOT have been an occasional brass tag used. If this is, in fact, true, a brass tag tractor would be only one of MANY in a series, so why the hype over a brass tag, as it would be like every other tractor of that year?
Does anyone know the absolute truth on this?
Will P
10-03-2004 13:07:16
 Re: Brass Tags in reply to Bob, 10-03-2004 10:01:17
It is a way for sellers to get bigger money for a tractor.
There was NOT an occasional brass tag inserted into the other tag materials production.
People, give up the hype.
Will P
Henry
10-03-2004 05:13:40
NOTHING there is no difference!!!!! !!
