JD GW ??s, front wheel part# questions Duane Larso
Bill R
02-05-2004 21:13:41
I recently purchased a John Deere G with round tube widefront, ser# 27759 which makes it a '48 (please correct if wrong). Now, I have a few questions, would a serial number research tell if it left the factory with a widefront? To my knowledge there were only 38 inch tires available for the G, so none of the G tractors have taller spindles? I know that True AW or BW have a different axle housing casting #, does this apply to the G series also? The tractor currently has non JD front rims, I have a set of JD1268R front rims off a 48' A parts tractor--would these rims be correct to use on my G? My letter series book lists JD1274 rim for the G, but is there a cosmetic difference? Did true GW have longer axles? Sorry about all the questions but i re-read the G chapter in JR Hobbs book and still had a few questions. As always thanks to all.
Bill R
A // B // GW // R Diesel
