How much wear is too much wear on a JD B crank???
Bob in Buffalo
10-02-2004 05:43:02
Hi, Maybe someone has the answer. I have a 1950 B that I recently acquired, that had a bad flywheel. It was cracked and needed replaced. I put what lookied to be a good used one on the tractor and it seemed to tighten well. After an hour of running, it is loose again. The splines on the crank really don't look that bad. I have a JD 70 Gas that had a bad flywheel, and the crank was in pretty bad shape, but a taper lock has solved that problem!! I just don't know if there is too much wear on the splines or not....they really don't look that bad. Anybody have any suggestions on how to tell, or how I can fix this with another used flywheel, as I really hate to spend another $700 plus for a taperlock!
Thanks in advance for your help!
Bob
Greg S
10-02-2004 07:22:33
 Re: How much wear is too much wear on a JD B cran in reply to Bob in Buffalo, 10-02-2004 05:43:02
Bob, Make sure the flywheel is good and clean. Both where the splines are, and where the bolts make contact with the clamping surface. It wouldn't hurt to clean the splines with MEK on both the crankshaft and the flywheel to remove any unseen oil. Even a minute trace of oil will reduce the ability for the flywheel to stay on the crankshaft. After you have adjusted the end play from .005" to .010", tighten the bolts as tightly as you can. What are you using to tighten the bolts? Maybe you just aren't getting them tight enough. I use the special flywheel wrench that John Deere made, but do a search, and you will find several ideas that Clooney and others have had for making special wrenches that will work. There is no torque spec, as the manual simply says, "Tighten flywheel calmping bolts securely.". One more thing to put odds in your favor would be to buy new bolts from John Deere. Lastly, try re-tightening the bolts after 15 minutes of running. Do this again and again, until eventually, the bolts will not tighten up further.
CPeter
10-02-2004 11:17:40
 Re: How much wear is too much wear on a JD B cran in reply to Greg S, 10-02-2004 07:22:33
A suggestion. Before you start again, get new grade 8 bolts. Also, the advice about retightening them is right on. I would check them the first time after 5 minutes and if I could move them at all, only go another five minutes, etc. Once things start to move, they also change shape and grow. The secret is to keep them from moving at all.
This is based on my experience. As for the grade 8 bolts, someone else may know better, but they are pretty tough and don't stretch much.
CPeter
Bob In Buffalo
10-03-2004 04:38:38
 Re: How much wear is too much wear on a JD B cran in reply to CPeter, 10-02-2004 11:17:40
Hello, Thanks for the advice! I am going to try a used flywheel on it I guess. When the flywheel is just slid onto the crank, it does have a little play before it is tightened down...it is easy to slide on. I am going to take your suggestions on the tightening, and see what happens. I am just not sure what constitutes too much wear on the splines...some guys say I should change the crank...I just don"t think it is bad enough to warrent a new crank.
Thanks again!
Bob
