Spark Plug question
John in IN
10-01-2004 19:24:13
I would like to know if a hot plug will make the engine run warmer than a cold plug?
Thanks much,
John
John T
10-02-2004 08:00:41
 Re: Spark Plug question in reply to John in IN, 10-01-2004 19:24:13
Hi John in IN, Im also a John in IN, down Bloomington way, where r u located??? Gerald has ya covered on the hot plug question, theres also many people who think hotter plug means a hotter spark, but as Gerald explained the hot refers to its ability to transfer heat.
John T
John in IN
10-02-2004 17:45:00
 Re: Spark Plug question in reply to John T, 10-02-2004 08:00:41
Hi John T,
I"m up north of Ft. Wayne outside a little town called Churubusco. Thanks for the info,
John
Gerald J.
10-01-2004 19:34:44
No. The heat of the plug is not the heat of the engine, its the heat of the tip of the ceramic insulator. A hot plug has a longer ceramic between the center and the ceramic mounting, poorer cooling so it runs hotter. Burns off carbon better, but if it gets too hot it causes preignition that can burn a hole in the piston.
Lean mixture can make an engine run hotter, late ignition combined with lean can burn exhaust valves and make the manifold glow.
Gerald J.
