exhaust manifold-8630
BMAN
10-01-2004 06:59:05
I'm looking for a good used exhaust manifold for an 8630 John Deere. So far no luck with salvage yards in Iowa.
Ray
10-01-2004 16:05:30
 Re: exhaust manifold-8630 in reply to BMAN, 10-01-2004 06:59:05
Anderson tractor at bluffton ohio would probably have one,there probably the largest late model
parts yard in ohio. (419-3588846)
Ray
10-01-2004 16:09:58
 Re: exhaust manifold-8630 in reply to Ray, 10-01-2004 16:05:30
There's also a place near Fort Wayne indiana
that rebuilds those motors for the 8630 and 8640,but I can't think of the name,it's on route
30.Maybe someone else has a better memory.
G-MAN
10-01-2004 07:44:32
Do you need both halves or just one? If you need the rear and find a used one, good luck getting the sealing ring out of it for replacement. They're can be a real bear, and without a new one, you'll likely have a leak. If you need the front one, it can be a pain to replace the studs, and the elbow mounting holes usually need heli-coiled. I know they're not cheap, but exhaust manifolds are one of those items where it's sometimes easiest and cheapest labor-wise to just bite the bullet and buy new.
BMAN
10-01-2004 15:12:35
 Re: exhaust manifold-8630 in reply to G-MAN, 10-01-2004 07:44:32
I need both halves
G-MAN
10-01-2004 15:24:24
 Re: exhaust manifold-8630 in reply to BMAN, 10-01-2004 15:12:35
Keep your eyes and options opened for more than just 8630s. The front half is also used on most or all of the 6619 powered forage harvesters, 8640, 8650, etc. The rear half is used on 7520s, 6030s, 8650s, 8640s, 60 and 70-series 4wds, and forage harvesters again.
