3020 ported hydraulic filter cover
Randy H.
09-30-2004 09:47:56
Does anyone know where I can get a ported cover for my hydraulic filter cover so I can pipe my 148 loader direclty into the system? I tried my dealer and they wanted $100.00 for that cover, maybe that is reasonable, but thought I would ask for other options.
thanks in advance
DJHoltom
12-09-2005 11:44:12
 Re: 3020 ported hydraulic filter cover in reply to Randy H. , 09-30-2004 09:47:56
There is a 1" plug just to the right of the three point arm on the back of the tractor. JD makes a fiting to replace the plug that has a 1/2 MPT. $20. Run your return to it with the same effect - less money
960
09-30-2004 18:05:14
Years ago we had a 3020 with cast iron cover and we drilled and tapped it and had no problems. $100 probably is not out of line as in my shop years back a 20 series came in with a damaged cover and inner spring and plate missing. A salvage yard charged $35 plus shipping then.
Gerald J.
09-30-2004 10:10:29
That's the cover from the 2640?
The cover on my 4020 was thick aluminum so I drilled and tapped it 1/2" pipe thread. There is a danger the return flow can crunch the filter, but I've not looked to see if that has happened. The official cover puts the oil in tangentially to avoid hitting the filter element directly.
Gerald J.
