Ron: Sorry to hear about your bad luck. G-Man did in fact post the official JD "How to resurrect a drowned Deere" instructions, so read those and then move forward. I'll just offer a few points I feel you ought to consider. Mostly, I would start in the front, draining fluids to remove the water, and greasing zerks to drive out out the water, and work your way back. Does the tractor have Power Steering? If so, post back, as I won't bother to cover that if you don't have it. If not, you might want to grease the fanshaft bearing. Grease the front wheel bearings and front pedestal. Examine the steering gear area and clean, dry, and lube as required. Then there is the obvious. Drain the Oilbath air filter cup, and let it drip a good long time. Refresh it with the proper weight and grade of oil and understand that after it runs for a while, the oil will drain from the wire mesh above and collect in the cup along with some water. No telling just how many times you might have to change that until you get it moisture free. Alot depends on how far up the water got and for how long. Oil the cups on the generator. Use compressed air to dry out the generator brushes and fields. Uncover and dry out the voltage regulator. Remove the distributor and spark plugs. Use air to clean and dry these as well. Get fresh plugs, points, etc. Leave the plugs out until launch time. Drain the fuel from the carburetor bowl, tank, etc. Pour a gallon of fuel into the tank and rock the tractor back and forth to slosh the water out. Drain and toss until you add some fuel and it's water free. Check it in a clear glass container. Then let it run to the carb and out the drain. Drain and toss until it is pure. On the engine, you need to drain everything, and replace the filter. You might want to hand turn the flywheel through a couple of revs to displace any water from the lines and pump. You COULD drop the plate on the bottom of the oil pump to drain anything out of there if you want. I would then fill it with very inexpensive oil, and use that to push any water out of the rings/rods/galleries/etc, and then, when it is time to run it, after just a minute, stop the engine and check the oil quality. If it is not too milky, you might be able to bring it on up to temperature. If you have any doubts, drain this oil, and always replace the filter, and run it a minute to mix it all up, then stop it and again observe the oil for milkiness. You need to be convinced that you finally have the engine oil clean and moisture free before you will run it at length. Drain the transmission, and here is a good place to use diesel fuel as a flush. Once running, drive the tractor with one wheel in a ditch, and then other wheel so that the diesel fuel has a chance to displace as much water from up in the axle housings as it can. Don't forget to drain the first reduction gear cover. I'm not sure if that is engine oil or gear lube, so do the appropriate thing there per your manual. Now you're back to the Custom-Powr-Trol, and here your manual will guide you somewhat as to where the drains are. I would fill this with diesel fuel and cycle it through, then maybe re-fill with some cheap hy-tran type oil to flush again. Again, only when you are sure you have removed all the water you can would you install the good fluid and try to run it. When you are ready to run it, I would watch the oil pressure gauge carefully, and stop the engine at 1, 5, 15, 30, and 60 minutes to see what the engine fluids look like. You might have to out a cardboard in front of the radiator to get it nice and hot. After all of this, the BEST thing you could do would be to get it on a load and get it hot enough to boil any moisture out of the residual areas. At minimuum, park it in the sun light a lot. You'll be surprised how much that warmth will help. Good luck! You have quite a chore ahead of you. Frank
