JWR, To begin with, when the Flywheels Left Hand Impulse timing mark is at the 3 o clock position in line with a flat mark on the tractors side and/or a mark on the bottom of the flywheel hub is lined up at the bototm of the flywheel cover opening in the 6 o clock position, if the flywheels on the right crank spline,,,,, ,,and the crank to cam is in time,,,,, ,and the cam to governor gear is in time,,,,, ,,the left piston ought to be at TDC,,,,, ,,,,,and YOU ARE RIGHT, the female drive slot in the governor shaft end that drives the mag OUGHT TO BE FLAT HORIZONTAL FORE N AFT. HOWEVER, all else can be right and maybe its only that the governor gear is off a tooth or 2 from the cam gear??? If only off a little (maybe a tooth or 2) theres still enough left/right CW/CCW mag timing variance to still get her to run. On the compression difference, the first thing I would do is remove the valve cover and insure theres no stuck open valves on that low side and if all the valves are going up n down as the engine is rotated. Also on that low cylinder, slowly turn the engine over and bring its piston up on compression and listen to see if compression is escaping out the carb (intake valve open or leaking) or the exhaust stack (exh valve open/leaky) or back out the crankcase (rings). If its real low, suspect a stuck open valve which you may be able to cure by removing the valve cover and rockers and using PB Blaster n WD40 etc and a small hammer to peck n shock n vibrate to free up the stuck valve. If you free it up, I would change oil and add 2 qts of rislone,,,,, 2 qts of auto tranny fluid,,,,, ,and the rest high detergent 10W30 oil n use her long n hot n hard to clean things up. Also check the valve lash in case one is too tight not allowing the valve to close fully !!!! Let us know, Good Luck n God Bless John T
