2 Cylinder question
bigw6
09-29-2004 11:21:40
I know the firing order is 1-2 but which side is 1 and which side is 2.I"m sure it doesn"t make any difference but I have a B.
Stuart martin
09-29-2004 11:26:36
 Re: 2 Cylinder question in reply to bigw6, 09-29-2004 11:21:40
The rule is that the cylinder farthest from the flywheel is number one. This would be the right cylinder if your sitting on the seat, but I could be wrong. Someone please correct me if I am wrong.
F-I-T
09-29-2004 11:31:38
 Re: 2 Cylinder question in reply to Stuart martin, 09-29-2004 11:26:36
Sorry Stuart, you are wrong. #1 is the left side when sitting in the seat and is closest to the flywheel. This would show up pretty fast when you slowly turn the flywheel over and look at the timing marks come up.
Frank
Stuart
09-30-2004 09:42:12
 Re: 2 Cylinder question in reply to F-I-T, 09-29-2004 11:31:38
not on a closed fly wheel model 60
F-I-T
09-30-2004 10:59:46
 Re: 2 Cylinder question in reply to Stuart, 09-30-2004 09:42:12
'Splain that to me. If you hand crank it, you turn the flywheel CCW, and the piston nearest you hits first.
The "closed flywheel 60" is no different that a "closed flywheel A" (or any Waterloo 2 cylinder), and on those, the top of the crank comes up and then forward, so the engine is turning CCW if viewed from the flywheel end, and the piston nearest the flywheel hits first. Been that way since 1924, and maybe the Waterloo Bay before that.
Waiting on your answer. BTW, never have seen an "Open flywheel model '60'".
Frank
Deereman
10-03-2004 16:22:36
 Re: 2 Cylinder question in reply to F-I-T, 09-30-2004 10:59:46
Sorry Stuart, but I have to go with F-I-T on this one.
