300 stalls
stu in nj
09-29-2004 09:41:36
i'm working on a 300jd 3 cyl gas. will idle but stalls under load. PLEASE HELP!!!
stu in nj
10-01-2004 16:03:51
 Re: 300 stalls thanksDalebigw6 in reply to stu in nj, 09-29-2004 09:41:36
I'll pull the carb rebild it. Let you know how I make out. thanks stu
Dale in IN
09-30-2004 06:22:40
 Re: 300 stalls in reply to stu in nj, 09-29-2004 09:41:36
Do you have the selonid load shut off on the carb. If you do it may not be open enough. I have one and over the years the load jet screw has become worn and the vibrations will change your setting. I have to keep a piece of small wire wraped around mine to keep it from shutting me down.
bigw6
09-29-2004 11:24:55
I am not familiar with a 300 but on other models i have learned the carb usually has an obstruction in it like rust or something of that nature I dont know if that"ll help you or not.
