1945 A
09-29-2004 06:48:45
Re: Goodwrench .. Rough running A in reply to hojon, 09-28-2004 13:11:10
I read your post yesterday about your rough running A, and was going to respond, but, your question about "baffles" in the DLTX 71 carburetor had me "baffled". I have the same carburetor on my "45 A, and there"s no sign of anything that looks like baffles, so not sure about that. As for the rough running, I experienced similar problems with mine when I first got her going, and one of the first things I discovered, was that the metering tube (not sure of the correct terminology, but it"s the brass tube you see just above the spring when you take the bowl off)---anyway, when I pulled that tube, all the little holes were plugged up with rust, once cleaned out, I could adjust the load and idle needles, and have a definite effect on engine running---prior to cleaning, turning the needles didn"t do squat. The other thing that comes to mind, is that I had a bad magneto----it would start okay, but, the longer it ran, the worse it got. It got to the point that I changed plugs a couple of times a day, and it would do the same thing---I think it was an issue of spark getting weaker as the magneto got hotter, so I"d check that, and if you have a coil and distributor set-up, check and see if the spark is good ALL the time. Basically, if she"s getting good fuel flow, AND good air flow (air cleaner is not plugged up), AND she"s getting good spark at the right time, she ought to go..... GOOD LUCK in finding your problem....it"s going to be one of those three things.... P.S. I didn"t mention valve lash... I think on the A it"s supposed to be .018-.020 with engine warm....
