B spark
Dave in S MN
09-28-2004 11:10:37
I have a 41 B that isn't running just right. I think it might be a mag problem cause i tried re-gapping the points and that helped a little bit but it still seems like it's only firing on one side.
You guys talk about the color of the spark a lot. I see a yellowish spark on mine. It's supposed to be blueish/whitish right? Should I try new points and condenser? Any ideas appreciated.
BTW the mag was gone through about 5 years ago. Seems weird that I should be having problems with it at this point doesn't it?
-Dave R
John T
09-28-2004 12:39:31
 Re: B spark in reply to Dave in S MN, 09-28-2004 11:10:37
Dave, assuming its really a magneto instead of a battery powered coil ignition, like the Wico XB or Delco Distributor (although some below still applies), if you remove the plugs n crank her over does the mag make a loud sharp distinct SNAP or a faint dull clunk??? If the cranking spark is the weak yellow and she makes a faint dull clunk BUT RUNS GOOD IF PULL STARTED and the plug wires removed yields that good blue spark when running, the mag may have a weak impulse spring. However, as you say it isnt running right, you could have a weak spark caused by OTHER THAN a mag spring problem.
1) The first things I suspect causing a weak spark are the plugs, then points, then wires, condensor or coil, cap or rotor, among other things. Try a fresh set of plugs and see how BOTH sparks look with them removed and wires atached but the sides grounded??? If weak there, just observe the spark between the wire end and 1/8 to frame. If its good there but NOT at the plugs gap, I wonder about the plugs, however, a fresh set shouldnt have any problems.
2) If the spark is weak from the wire end to 1/8 to frame, see if its the same on BOTH sides?? If its strong on one side but weak on the other, I suspect a wire or cap or rotor problem. Try swapping wires n sides to isolate whether its a bad wire or the sparks always weaker out one cap tower. If always weaker out one cap tower and its not a plug wire problem, then I suspect a cap or rotor problem. Remove the cap n inspect it for cracks or carbon traces and the rotor tip(s) and look for differences at the rotor tip(s) and inner tower terminals.
3) If the spark is just plain weak regardless of which side and its NOT a plug or wire or cap or rotor problem, then inspect the points to insure they are gapped proper?? Next, if they are badly burned or pitted or carboned up or heavy gray oxide coated, you might first try to clean/file/polish and re gap them and if that helps, I would go ahead n get a new set n have em ready to install.
Oxidized or burned or mis gapped mag points are a common cause of a weak spark EVEN LONG BEFORE FIVE YEARS, so if the plugs are new and you have good wire core wires and the cap n rotor are all good, yet the spark is weak wimpy yellow, YES try to clean/file/ploish n re gap the points and get a new set if that helps.
Theres lots of other possibilites like fuel n carb n timing etc., so post back your findings n we will proceed further if needed.
Good Luck n God Bless
John T
