70 electrical problems
pete
09-28-2004 09:25:13
First off let me say im a die hard IH guy, so this is hard for me to do. But i am working for a guy with a JD 70 gas and we are having problems with the electrical system. Its a positive ground. We have to pull start it because the battery is dead, but when it is running if you switch the lights on the tractor will die. Is there any suggestions to my problem? thanks for your help.
buckeye al
09-28-2004 14:13:33
 Re: 70 electrical problems in reply to pete, 09-28-2004 09:25:13
What John said. But also, make sure the regulator is well grounded! Original regulator was a saddle mount to the generator & if the regulator is not well grounded to the frame of the generator the charging system will not work properly.
John T
09-28-2004 10:02:00
Pete, to begin with, it either needs a new battery, or if the old one is still good, a good charging at least. It sounds like it barely has enough energy to power the coil ignition and then adding the lights either kills it due to such a low battery or there may be a switch problem.
Give her a good charge and if necessary try a substitite battery n see what happens. Once charged, if shes sat a long time, the Generator may need polarized. To do that once charged and assuming shes all wired right, temporarily dead ground the Gens Field post to its case, then momentarily flash jump a wire from the Voltage Regulators BAT terminal over ot its ARM (or GEN) terminal and you ought to get a small spark.
Try the charge and/or a known good substitute battery and polarize the Gen then see what happens.
John T
