3010 rebuild cost est.
Brad B
09-28-2004 05:18:22
Need to have my 3010D motor done. What is a ballpark price assuming the motor has never been done with over 8000 Hrs. I am in upstate NY. I understand this is a hard question. I do not know the history on the tractor so lets say worst case senario. Thanks
Brad
JMS/MN
09-28-2004 12:06:00
 Re: 3010 rebuild cost est. in reply to Brad B, 09-28-2004 05:18:22
Local mechanic, ex-White dealer, did my 3020 8-10 years ago with aftermarket kit. Cost was about 2700. Within three years, the liners were worn out from cavitation, so I had the local JD dealer do the job- about 4000. No more aftermarket junk. This is not a field tractor- just a loader tractor. Still in fine shape now.
Tyler
09-29-2004 05:29:23
 Re: 3010 rebuild cost est. in reply to JMS/MN, 09-28-2004 12:06:00
Concerning the eroding of the liners, it is not just an aftermarket thing. We have torn down hundreds of engines over the years and many of them had the same electrolysis problems , with Deere liners. Now days nearly all of the engine parts are made in the same factories for all the suppliers, everything is a lesser quality than it used to be, including Deeres.
Tyler
G-MAN
09-29-2004 07:42:17
 Re: 3010 rebuild cost est. in reply to Tyler, 09-29-2004 05:29:23
I haven't taken apart anywhere near hundreds of Deere engines, but haven't seen a Deere liner come out looking like that Reliance liner, even when draining out coolan that looked like pond water. Cooling system maintenance is the main thing, but the aftermarket kits are simply not as good as OEM kits, regardless of brands. The grooved main bearings shells for the caps proved that. Those grooves in the lower mains reduced bearing load area by a substantial amount, and the crank had the additional wear to prove it. Anybody is more than welcome to use the cheapest parts they can find. Just don't blame it on the guy doing the work if the engine lays down prematurely.
G-MAN
09-28-2004 13:44:35
That's exactly what happened on the 4230. Coolant in the oil. I dropped the pan and it was dripping at a pretty good rate from the #2 liner. I figured it was an o-ring, but it turned out to be a pit right through the entire liner. I don't know if they don't harden those will-fit sleeves as much, don't use the same metals or what, but they won't last like an OEM Deere liner, particularly if the coolant isn't kept up to snuff.
Rodney A. Johnson
09-28-2004 08:49:12
I had my 3010D rebuilt about 2-3 years ago. All parts were JD and the labor was free (cousin used it as a project in his Diesel Mechanics classes).
The 3010 had the old style gears on the camshaft, oil pump, and fuel injection pump. These gears (larger teeth) were known to wear badly, thus had to get a new cam shaft, and new gears for the oil and fuel injection pump. I believe the cam shaft ran about 600 USD.
I lucked out on the fuel injection pump and thus only needed a 25 USD kit to replace the plastic thing that breaks in those rosamaster pumps so often.
After it was all done, it cost me a little over 3800 USD in parts. A fair amount of work had to be done on the block. Noone could really say why it got warped so bad. Machining of the block, head, and pistons (had to shave the new pistons to match the block) was over 500 USD.
If your crank is bad, I've heard quotes of close to 2000 USD for new crank.
All parts were bought through a local JD dealer in central MN. All the valve work was done by my cousin. I had the injectors rebuilt a year before the overhaul and cost about 100 USD at a local shop that specialized in fuel injection work.
The parts cost also included new through out bearings for the PTO and transmission. Fortunately the clutches were in good shape, so I did not need to replace them. I did price a new tranmission clutch plate and was about 700 USD. Didn't price the clutch plate for the PTO. You need to split the tractor if you do a complete rebuild of the engine, and is a good time to address any transmission or clutch issues.
If you don't do the work yourself and have to pay someone to do the labor, note that just splitting the tractor will run you over 1000 USD.
Do not be surprised if you get close to 8000 USD into the tractor...but you will likely have a sound tractor that will last you the rest of your life.
G-MAN
09-28-2004 07:43:32
That depends on the condition of the engine, how much work you want to do and what parts you use. I strongly recommend using a Deere overhaul kit. I recently overhauled a 4230 that had been rebuilt with a Reliance kit and was not impressed. The liners had eroded quickly and one had a pin-hole leaking coolant into the oil. The rod and main bearings were Federal Mogul units, but the mains had full grooves in the bottom bearings, while Deere kits use a full shell, etc.
Brad B
09-28-2004 08:38:52
 Re: 3010 rebuild cost est. in reply to G-MAN, 09-28-2004 07:43:32
My main concern is oil pressure light comes on at 1000 RPM or less. I had it set last winter per the book and have the adjustment all the way. Its worse after working the tractor, 1200 RPM or less.
So I want to get it taken care of before major problem in the middle of hay season. I am willing to make it right as I plan to keep the tractor. I am very happy with it.
Karen
09-28-2004 05:46:36
We're in upstate NY and may be able to help you. Email me.
